(1) 2 3 »
Re: 4age 20v/4agze in a datto ute??
From Perth Austarlia
If I had my time again.......I wouldn't bother.
The 20V has the water exits at the rear...makes it bloody difficult. The sump is a long way forward, making it impossible to fit standard swaybars.
The only RWD gearbox which bolts on..a T50 is rare..the reason they are rare is because they are piss weak. Because they are rare they are also expensive.
(Does it then follow..that they are expensive because they are pissweak???)
U can't get cheap replaceable uni joints...
Depending of which T50 you get..one has the starter motor on the exhaust side..Leaves bugger all room for an exhaust. all that heat wouldn't be doin the starter much good!
The link rod hits the gearbox...still sortin this out.
But apart from that..its piss easy .
The 16V is a different beast. It has the dizzy in the right spot, water outlets in the right spot. But still the other issues remain and why would you bother doin a conversion where you'll end up with 100KW anyway??????
The cost of most conversions probably ends up being the same amount..Get yourself a CA18DET. Start with 130KW. and a bleed..etc easily have 150KW..have a GB which actually lasts, Have less hassles with cooling...etc.
Posted on: 2005/3/11 4:32
From Mackay
No comment As i'd hate to upset a few people
Posted on: 2005/3/9 7:50
Not too shy to talk
From Narre Warren Vic
T50(sprinter) box is the only bolt up box for 4ag but there a bit fragile and the gze will raquire an ag flywheel for t50(clutch is to big). W-series boxes are tough but need a custom bellhousing and are usaly expensive and poor quality.I belive ca and gze are simular weight but ca has 200cc's on the gze.7af is like a ca20, a sad retarded cousin of the real thing with not much potential.Unless youre keeping the blower I'd go the ca,no home made bits.
Posted on: 2005/3/9 5:38
From California
You lads can swap engine makes and get a few grumbles from the diehards, but if we do that in the states, you're ridiculed.
wot sorta wog are u "wogboy"
Posted on: 2005/3/9 4:59
From Mackay
I'm currently in the process of putting the 4agze into my dato ute but I've taken the blower off and replacing it with a gt25r turbo my main reason for putting this motor in was it's a lighter motor than a CA and it produce quite a bit of HP and there a pretty strong motor not that i'm saying that CA's are no good but each to there own.
And life would be pretty borning if we all thought the same
Posted on: 2005/3/8 13:10
From Brisbane, Australia
in that case, ive seen a 350 chev in a shelby cobra replica
they can stick whatever they want in those horrible lumps of wannabe crap. cobra replicas should be banned, and all those guys with their mid life crisis can go drive MX5s where they belong...
if u want to be really unique, u could track down a 7age out of a camry and fit the 4a head to that. with a bit machining to a few things, and some tuning, and u have a 1.8l 4ag
yeah good idea. why do things by halves, when you can could be really broke! ever heard of a CA18? 1.8l without any expensive machining or buying other heads or bottom ends. And then there's the factory turbo version as icing on the cake.
Posted on: 2005/3/8 12:23
just ;ike those dart motors, half chevy and half ford parts and you can interchang them depending of capacity etc.....
Posted on: 2005/3/8 12:13
From ACT
It would be like stuffing a Ford motor in a 57 Chev
in that case, ive seen a 350 chev in a shelby cobra replica, so in my opinion, go ahead with the conversion. if i remember corectly, the t or w 50 gearbox(forgot which one they use) that is behind the 4a's stock fits str8 into the datto trans tunnel. if u want to be really unique, u could track down a 7age out of a camry and fit the 4a head to that. with a bit machining to a few things, and some tuning, and u have a 1.8l 4ag
Posted on: 2005/3/8 12:08
Toyota is the enemy! It would be like stuffing a Ford motor in a 57 Chev! personally, I wouldn't use anything other than a Nissan/Datsun engine in my 1200. But I did have a Datsun 240K with a Leyland V8 in it, so don't let me stop ya!
sidedraught wrote:
If you think its still somehow a "Datsun" engine because it has Nissan on the rocker cover you are just kidding yourself.
huh?
Posted on: 2005/3/8 11:57
Not too shy to talk
Funny, I'm looking at puting a ca18 into my sprinter ,some say the ca was a progresion from the 4ag just as the 4ag was to the ford bda motor.20v and gze are awsome motors but for my money(or lack there of) I'm turboing the de and it should cost a lot less than any turboed 4ag variant.Just my 2c worth.BTW my sprinters getting r33 front and xf rear brakes and my old 1200 coupe had hilux brakes and is just about to get a celica 5 speed. Don't let politics get in the way of a good idea.Its all jap, its all good.
Posted on: 2005/3/8 9:37
(1) 2 3 »
