Re: Engine swap problem
From Brisbane Australia
Hi Nino, this engine swap is not hard just compare the two engines and take a note on what bits are in different places and it will make it a lot easier when you go to bolt it in.
What are you doing with your old engine ? I am chasing all the alternator mounting hardware let me know what you would want for them
cheers Ade
Posted on: 2005/5/3 11:53
Quite a regular
From qld qold cost
Thanks for that
Dose any one have alternator mounts for sale that will fit this engine
Thanks
Posted on: 2005/5/3 9:41
nino wrote:
Hi
I have a problem I just brought an a12 engine and the distributor is at the front of the engine (the old engine had it towards the back of the engine)
My question is why
Posted on: 2005/5/3 9:29
Love your Datsun.
Treat it well.
From Warburton vic
It sounds like you have an old a12 if the alternator is near the bottom hose its an old a12. what car is it in?
Posted on: 2005/5/3 3:31
From south australia
the engine is newer most probebly from a 120y or sunny you will have to make up some plates about 2 or 3 inches long and drill them out to fit the engine mounts
go have a look at te tech section then look under engine advice then how to fit a a14 /a15 engine
it shhould give you an idea
Posted on: 2005/5/2 14:27
Engine swap problem
Quite a regular
From qld qold cost
Hi
I have a problem I just brought an a12 engine with an automatic gearbox because I blow up my old engine (The old engine was a manual). The problem is that the alternator is on the other side of the engine (but I didn
Posted on: 2005/5/2 12:57
