Re: L20B swap question...
From Perth Western Australia
Anyone else with L20b swap experience care to chime in?
CHIME!
my website tech article
just in case you haven't seen it
(article is also avaliable at www.datnet.org in tech section)
Posted on: 2005/7/8 16:07
Not too shy to talk
From Barbados
well i have a l16 in my b310
i only modified my 1200 cross member
and every thing else worked good
the only problem i have is axle tramping
so some input on that would be helpful
Posted on: 2005/7/8 13:57
From Arlington, TX, USA
L18_B110 wrote:
...the 310 is a much wider bodied car, I suspect there will be a significant difference to the 1200 x-member.
I might be missing something really obvious (it wouldn't be the first time!), but adapting a x-member from another non L series powered car just seems like making extra work for no benefit...
The only real reason is for L-series engine mounts. But the if the B310 Xmember needs to be narrowed to fit, it would be simpler just to cut off the Stanza "pedestals" and weld them onto the 1200 Xmember. Especially since the B310 control arms will bolt right up to the 1200 Xmember.
Posted on: 2005/7/8 6:14
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
GreaseMonky wrote:
wouldnt it be very simalair to the z series swap?
Yeah, basically, other than the height difference. The Z20E/Z22E is about 1" shorter than an L20B.
Posted on: 2005/7/8 6:05
From Vancouver WA. U.S.A.
Posted on: 2005/7/7 7:42
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
From Brisbane, Australia
you might also want to check the distance between the holes for the control arms. keeping these within the same ballpark as the 1200 crossmember is important for steering geometry. As the 310 is a much wider bodied car, I suspect there will be a significant difference to the 1200 x-member.
I might be missing something really obvious (it wouldn't be the first time!), but adapting a x-member from another non L series powered car just seems like making extra work for no benefit. I think its easiest to simply make mounts for the 1200 x-member, and slight mods to the sump to clear x-member
Posted on: 2005/7/7 7:07
Posted on: 2005/7/7 7:02
L18_B110 wrote:
This is all based on modifying the 1200 x-member, the Stanza x-member would require much more work to fit into the 1200.
I picked up a complete front suspension (with Xmember) from a B310 today, so I am first going to see if the B310 Xmember can be made to fit. If so, I'll probably make my own engine mounts to get the L20b in there. I am hoping I can get it to fit without extensive re-working of the crossmember center section, but we'll see...
Posted on: 2005/7/7 7:00
Thanks for the clarification.
L18_B110 wrote:
I didn't have any problems getting it engineered for road use over here, but I believe you guys don't even have to do that!
Yeah, we are very fortunate there.
Too wide?
Posted on: 2005/7/6 14:13
that part about the "hoop" was actually a quote from one of my posts here. Basically I moved the centre section of the x-member between the engine mount brackets rearwards about 20mm and down about 10mm (to the same height as the drag link) to allow me to fit the engine as low and as rearwards as possible. I mounted the engine so that the drag link just missed it at full lock (it rises slightly as steering lock is applied).
Even though I did the conversion with an L16 block, I never had any trouble fitting the 20mm taller L20B in there. Others have done the L20B conversion without cutting and shutting or lowering x-members.
I didn't have any problems getting it engineered for road use over here, but I believe you guys don't even have to do that! It wasn't technically legal for Improved Production racing here, but I built the car before I ever got involved in racing, or even considered it.
Posted on: 2005/7/6 5:22
