Re: US 1200 Steering Box .
From Vancouver WA. U.S.A.
I have a 1200 column and stearing box if you are interested
Posted on: 2005/7/23 7:20
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
From Adelaide, Australia
regarding shortening the pitman arm, is there any other pitman arm you can use? Ive heard a while back that corolla ke30 or something arms can be used, as they are shorter.
Posted on: 2005/7/21 10:29
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Bay City , Michigan , United States .
I 've tried Detroit Ball Bearing and they say they can't cross reference it with anything .
Sounds kind of hokey to me but I'm no bearing expert . Maybe there is a website that I can look up . Thanks for the help so far guys . Anyone else have any ideas ?
Todd .
Posted on: 2005/7/20 22:43
Not too shy to talk
From Carson City,NV USA
If its just the bearing and lower race check out a local bearings part house they may be able to match up with what you need.
Posted on: 2005/7/20 21:42
From Sydney, Australia
careful...please only shorten the pitman arm.
Shortening anything else will seriously affect bumpsteer.
Posted on: 2005/7/20 16:43
The 1200 gearbox already has the best ratio in the Datsun lineup. I hear some racers shorten the the steering arms to get a quicker response.
Posted on: 2005/7/20 16:34
I would also like to know, i just replaced the upper bush in the steering column, bastard of a thing that was, but i would like to rebuild the box itself. Is there people out there who specialize in rebuilding steering boxes, what about changing the ratio?
Posted on: 2005/7/20 13:44
IPRA Build
So the b210 steering box sounds much the same as a PL510 box which is about 2" to long .
The O/A vertical length of the b110 box mounted in the car is about 8". I had thought about just swapping out the whole assembly for a 510 box since I have two of those cars at home but the problem is when you compensate for the extra length of the 510 box and mount it higher in the b110 chassis it hits on the exhaust header . Yikes , this was supposed to be a simple fix . Any one have a better idea ?
Posted on: 2005/7/20 12:34
Good question. The assembly is different (B210's use a flexible coupling between box and steering column, B110s have the steering column attached to the box). It is possible the gears and other parts inside are the same, not sure if anyone here knows?
Posted on: 2005/7/20 6:45
Hi all ,
I'm new to the forum and am from the US .
I'm in need of a 1200 steering box preferably with column . Also will the B210 steering box work ? What I really need is the bearings and the bearing race on the bottom end of the steering shaft . This is for a roadracing car that I haven't been able to use yet this season because of this very need . The track that we call our home track can be seen at www.waterfordhills.com . Thanks for any help .
Posted on: 2005/7/20 0:12
1972 Datsun 1200 Coupe .
Race Hard , deny everything and demand proof .
