Re: r31 diff
From sydney australia
with the 200b discs & calipers,there are two sizes,the earlier ones are 10 inch,while the later ones are the same size as the stanza & the calipers are the same.the changeover is roughly
the middle of 1978.you can also fit 11 inch mitsubishi verada discs & commodore calipers,this should all be mentioned under the brake section in the tech files.as for the diff,lsds are available,but are very expensive,while the spring loaded locker is
controversial,because some people swear by it,while others swear at it.
Posted on: 2005/8/11 2:16
Re: r31 diff
From ipswich
locker? wont that mean that the diff will be permanitly locked
i want this car to perform well on dirt and street/track and the car will be registered
Posted on: 2005/8/11 1:22
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: r31 diff
From Canberra
so is there any mods i can do to the ute diff so that i can "bag up" both tyres
CIG locker
can the stanza struts be further modified, like fitting larger calipers and disks
I've read that 200B rotors are one inch larger and bolt up, not sure what, if anything, has to be modified.
Posted on: 2005/8/3 2:11
Re: r31 diff
From ipswich
i was only gon to turbocharge my a12 so maybe the r31 diff is a bit to much, so is there any mods i can do to the ute diff so that i can "bag up" both tyres
how much shorter does the r31 diff need to be, is that so that it will fit inside the guards
Posted on: 2005/8/3 0:58
datsun 1200 ute
Re: r31 diff
all centers are viscous I assume?
Posted on: 2005/8/2 1:32
Re: r31 diff
From Bris-Vegas
I'm not sure but i've heard VL commo and mabye VN Lsd's fit straight in but dont take my word for it....mabye someone else can confirm this.
I can confirm..... EA / EB falcon LSD centre's fit too.
Posted on: 2005/8/2 0:40
CA18DET '74 1200 ute project
Re: r31 diff
From Brisbane
R31 diffs are the same as a VL turbo, which in the executive, are just an open wheeler. The LSD in the VL's only came with the calais, which are pretty hard to come across. The R31 diff is pretty strong, and low1000 is right they do need shortening and unless your using something pretty powerful i wouldn't bother, cause it's a bit of a stuff around...
Posted on: 2005/8/1 13:24
Re: r31 diff
From sutho shire, NSW, AUS
r31 diffs are tough and probably a bit over the top unless your goin for an aftermarket injected turbo engine ie. CA, SR or 4AGZE (TE). they do have the same stud pattern as a 1200 (4 x 114.3) but are too wide and need to be shortened.
LSD wise only the sillouettes and GTS 1 and 2 vairents of the r31 came LSD.
Elliott
Posted on: 2005/8/1 13:02
Re: r31 diff
From Melbourne AUS
stanza struts can be used in 1200's with the right combination of components..
both round and square healight models can be used... the 1980+ square headlight model has large girlock calipers.. the earlier round headlight model has smaller calipers with tiny pad surface area and arent really worth using..
R31 diff has been used before but requires shortening
hope this helps
Posted on: 2005/8/1 12:56
1973 B110 A12
r31 diff
From ipswich
what is the compatability of the r31 skyline diff with a 1200 ute?
i came across the r31 diff today at the wreakers and i found out that the it has the same stud pattern as the a series pulsar, which id say would be the same as the 1200
the diff has 3 point linkage, disk brakes, sway bar an i think it has a lsd center
also came across a stanza with the same stud pattern but im not sure weather the front struts are comptable with the 1200 as i recall somebody saying that there are 2 types, the stanzas with the round headlights and the rectangle headlights
Posted on: 2005/8/1 9:37
datsun 1200 ute
