Re: disc brakes all round for 1200 ute
From brisbane
cant u use the original diff of the 1200 ute? thats wat i was gona do
Posted on: 2005/9/3 6:08
From sydney australia
jono,the best place to get a h190 that wont be whiny is probably a s12 gazelle.these come in 3.7:1 & 3.89:1 ratios,manual being the 3.7:1.
or the z24 powered urvans had 4.1:1 h190's.all of these are 4 stud,so no change of stud pattern.
Posted on: 2005/9/1 5:38
From brisbane
ill be running 15 or 16 inch rims so that shouldnt be a drama
Posted on: 2005/9/1 3:10
hmm,
im putting 200b struts and discs in my ute front end. i would also like to put a disc brake rear end in. But i think im just gunna put a H190 under the back. my dad has the machines to shorten them.
Does it matter what H190 i use? i want it to be a disc brake model.
the reason i choose the H190 is because of the alloy LSD available to them. and coz its a datsun diff.
but that brings me to my next question, i have previously read about setting up the brake booster? i have a stanza booster, 120y booster and a 200b booster. the 200b has rear end disc brakes. ( im pretty sure it does ne way?)
and that brings me to my last question. where do i get a H190 from?
I will swap a 1200 ute diff for a H190 in GOOD condition. i dont want a winey diff. and i will also swap another 1200 ute diff for the LSD centre.
sorry bout the long post. back on topic ai?
jono.
Posted on: 2005/8/31 14:59
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
bluebird trx or lx rear discs will work,but they need 14 inch wheels as a minimum.
Posted on: 2005/8/31 12:41
From penrith
Bluebird disks on the rear fit onto the ute diff.
any particular type of bluebird? i heard wagon ? and also heard u needed an "adapter plate"??
Posted on: 2005/8/31 8:59
From sydney
On the front ,1200coupe,120y, on the original struts.
or you could put in stanza struts and disks, and then the list goes on and on.
Posted on: 2005/8/30 7:40
From brisbane
hey guys i was just wondering if any of u know wat kind of brake rotors from wat i can use on my 1200 ute?
Posted on: 2005/8/30 7:36
