Re: removing x-member without removing engine
From Sydney
When I did my in chassis rebuild several months ago, I jacked up the engine and supported it with a suitable car stand on the crank pully. then I could drop the X-member and take off the sump and take the bottom end apart.
[ I had the engine jacked up enough, so tha the gear box bell housing was up against the transmission tunnel padded by ragging.] There was no sideways movement of the engine.
Another option is to use a suitable engine hoist to support the weight of the engine without actually removing the engine.
cheers
Benny
Posted on: 2005/9/21 10:05
From Springwood NSW, Formerly Tas.
well its in at my school workshop so everything is there, cranes and sh!t better get to it tomorrow then
Posted on: 2005/9/21 10:03
1978 120y Coupe.
From Brisbane Australia
the only way that I can see would be to remove your bonnet and hire an engine crane, that way you can take the wait of the engine, hell I have done an in chassy sump gasket so anything is possible.
Ade
Posted on: 2005/9/21 9:57
yeah i tried to tell my dad you cant do it cause it holds up the engine, looks like a bit more work than i wanted
Posted on: 2005/9/21 9:49
1978 120y Coupe.
Idont mean to piss on your parade but xmember supports engine only other way is to support engine and then remove engine
ade
Posted on: 2005/9/21 9:41
how do i do it, i bent it and i need to replace it so i need to get it out but cant be bothered taking out the engine
Posted on: 2005/9/21 9:33
1978 120y Coupe.
