Re: 1400 or 1500???
From Christchurch NZ
The vannette motor will bolt straight in. Just use the mounts and brackets off the A12. The sump will fly in, so don't worry about changing it.
Posted on: 2005/10/7 20:38
Forced Induction!
Re: 1400 or 1500???
Go with whatever's less expensive and less use on it. They are both great engines.
The A14 and A15 have same peak horsepower usually (may depend on country or car model), but has a different feel. The A15 has more low-speed horsepower (torque) than the A14, so it feels less 'peaky' and therefore feels 'slower' than the A14 -- even though it will accelerate your car faster.
Ask the man who's had both A14 and A15 in his 1200. Given the same carb, heads, cam, and exhaust, the A15 is more powerful. But with the same peak HP since the limiting factor is the carb, heads, cam and exhaust.
I dunno if A15s can easily be modified to rev over 8500 rpm. I rode in one A15-powered 1200 that did 8000 RPM. Sounded nice!
Posted on: 2005/10/7 8:41
Re: 1400 or 1500???
From Adelaide, Australia
Oh as for Wreckers telling porkies, so your in adelaide i guess you phoned Grand Theft Auto. They will say something like 'bloody oath mate an fj20 will fit' 'nah no modifications mate, here have a vb', just to sell you one...
Just go down u-pullit and have a look at a vanette, im sure you will be able to see whether it'll fit or not.
Posted on: 2005/10/4 11:14
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: 1400 or 1500???
Original A15 sumps have 'power bulges' on one side to clear the rods of this long stroke engine.
So a12 sump will not fit, however a mate has an a15 out of a vanette in his 1200 and he had no problems with fit apart from engine mounts of course. which as you have a sunny and not a 1200 you will not have engine mount problems.
Cheers
Posted on: 2005/10/4 11:06
IPRA Build
Re: 1400 or 1500???
Quite a regular
From Adeliade, Australia
Called a wreckers today and they suggested that the 1200 sump does fit without any problems! Has anyone done the same conversion and used the vanette sump?
Its quite difficult to ontain a sump from a 1400 or 1500 sunny, this is the reason why Im asking this question!
Posted on: 2005/10/4 10:07
Re: 1400 or 1500???
The sump from a Sunny [B310] A12 will bolt onto the block of an A15, but the rods will hit on one side.
If you have a look at your oil pan & compare to the Vanette one, you should see any discrepancy. I believe [but can't guarantee] that the Vanette sump will fit the Sunny chassis.
Posted on: 2005/9/27 11:47
Love your Datsun.
Treat it well.
Re: 1400 or 1500???
Quite a regular
If I take an A15 from a vanette, will I have to change the engine mounts in my sunny?
Also will the sump from the vanette fit? If not will my 1200 sump form my sunny motor fit onto the A15?
Posted on: 2005/9/27 8:36
Re: 1400 or 1500???
the a15 has more grunt for the road and is the choice for racers like champion Steve Newing. He had an a14 with the a15 crank which made it an a15 anyway.
The round port a15 was also supposed to be available in the vanette. This would explain 69hp. But the sunny a15 supposedly 82hp. Either way the long stroke is only a gain for the A series especially with a 78 or 79mm bore.
Posted on: 2005/9/25 18:37
Re: 1400 or 1500???
From Townsville NQ
The differing in power ratings is because early engines had SAE power vs late ones having DIN power, or something.
basically earier stuff was tested without alternators etc hooked up, later stuff tested as it is in the car.
also, SAE was rumored to mean "Say Anything Exciting"
Posted on: 2005/9/25 13:29
Re: 1400 or 1500???
From South Dakota USA/Trinidad and Tobago
if i'm not mistaking the a14 and a15 heads are similar in that the ports are oval-shaped.you don't have 2 change the radiator.i'm still carrying my original a12 radiator and engine cools perfectly.so you could keep that radiator(keep the car original as possible).btw try 2 get a clutch fan(if the engine doesn't already have one).it has more blades than the normal 4 blade fan and cools better.trust me i know.
Posted on: 2005/9/25 11:28
