Re: 720 4wd Diff Questions
From Central Vic
720's have a h190 in the rear and a R180 in the frount if its a low ratio (written on fire wall) the frount diff is worth quite a bit for 1600 rally cars
there might be something written on the fire wall tag I think
Posted on: 2005/10/13 12:07
From sydney australia
the easiest way to check for an lsd is turn one of the axles.if the other axle is turning towards the same direction,ie towards the front of the car,it's an lsd.if it turns the opposite direction,it's an open centre.the 720's were all h190's,& i don't think the lsd would be adaptable to a h165,particularly that alloy 4.11
in the back of the 1000.
Posted on: 2005/10/13 11:37
From Canberra
h190 rear r180 front I think...
Posted on: 2005/10/13 10:04
From Sydney
from memory they will fit H190's
Posted on: 2005/10/13 6:24
From Newcastle (NSW)
Hey everybody!
I've found a Nissan Diesel 720 4WD dual cab ute that is being wrecked. It has both diff's in it.
Does anyone know how to tell if they are LSD diffs and can the LSD centre be adapted to a H165 or similar live axle diff.
Posted on: 2005/10/13 5:57
