Re: auto tranny trouble
From Sydney Australia
yeah proably the vaccume line to the vaccume modulator on the side of the gearbox
Posted on: 2006/1/16 6:09
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Tracy ,Ca
1st ? does the trans fluid smell burnt, if so internal trans problem
2nd ? was it ok before carb swap if so look for a dissconected vac line to trans
Posted on: 2006/1/16 2:52
From bend oregon
the fluid level seems to be good maybe a touch full.
Posted on: 2006/1/16 2:06
yeah stupid me found out too much fluid is no good the hard way took all day to work it out. the dip stick isn't perfect cause the car is running when you check (one side of the dipstick will be higher).......measure from the hgher side and you should be right good luck
Posted on: 2006/1/15 10:08
Yes, it could be low on fluid. Fill it to the minimum line, then drive it 15 minutes. Then top it up to the regular mark. Don't overfill it or similar problems can occur.
Posted on: 2006/1/15 4:45
sounds like you need fluid in the auto
Posted on: 2006/1/15 1:40
From bend oregon
anybody know these auto trannys or good ref points
Posted on: 2006/1/14 22:33
From bend oregon
5sd are real hard to find around here every body crushed the little cars have to travel across the mtns to get one. might have one in afield about 45 miles from here
Posted on: 2006/1/14 1:07
From California
convert to a 5spd. seriously.
Posted on: 2006/1/14 0:39
auto tranny trouble
From bend oregon
Symptoms motor revs to 2500 rpm and tranny slowly catches up. The old weber came off then put the stock carbby on Weber needs rebuild. Checked for vacum leaks and so forth. Helping a friend new to the datto world.
Posted on: 2006/1/13 14:26
