Re: Radiator Hoses
From Canberra
And why bother with the flexi hose, when the "right" ones are available?
The flexis are not recommended because they introduce drag into the coolant flow.
I've never used them myself i've just seen them on the shelf and thought they might be suitable if the correct one could not be sourced. I now know better
Posted on: 2006/2/26 6:38
Re: Radiator Hoses
From Tamworth , NSW
ive never had problems with hoses and such.
between supercheap, autobarn especially, or the nissan dealer i havent had a worry getting any hose ive needed.
Posted on: 2006/2/26 2:29
Re: Radiator Hoses
Posted on: 2006/2/25 16:58
Re: Radiator Hoses
ive tried the flexi hoses and dont recomend them highly, they dont bend on the right angle for the bottom hose, the top ones ok but not the bottom, particulalrly bad if you want to upgrade your radiator too.
Posted on: 2006/2/25 0:31
Re: Radiator Hoses
From Canberra
fits perfect if you trim 1/2 an inch off it.
I noticed this with supercheap hoses too, on a 120Y.
why not use the flexi hoses and wire them out of the way? I've got the standard ones but with wire to keep them away from the alternator.
Posted on: 2006/2/24 10:47
Re: Radiator Hoses
From Brisbane, Narangba
Just walk into supercheap or the like and if they dont have a 1200 hose buy a 120y radiator hose fits fine and fits perfect if you trim 1/2 an inch off it.
Posted on: 2006/2/24 8:35
Re: Radiator Hoses
From Stone Age somewhere in U.S.A.
upper hose 21501-H1000
lower hose 21506-H1101 (with T for heater)
still available from Nissan here in the USA
Posted on: 2006/2/24 7:51
Re: Radiator Hoses
From California
sleeper, you can order the nicer, 1200 block tube from nissan
Posted on: 2006/2/24 7:30
Re: Radiator Hoses
From Burbank, CA
the 2 piece hose is kind of nice, the 310's have a ugly fitting coming out of the the engine with 2 outlets too close together and the heater bung is some wacky size i can never find the right hose for.
Posted on: 2006/2/24 2:50
|||\ 81 KPB310 /|||
Re: Radiator Hoses
Yes, Nissan can still get them. Price is not bad.
The part numbers for the hoses are in the tech section article Parts Sources: Where to Get Parts for Datsun 1200s.
It also lists aftermarket part numbers and prices.Quote:
About $13 [USD] each from Nissan. About $8 each from others
Be aware that in USA we got a two-piece lower (because of the heater). Heater-less cars may have one-piece hose.
Lower Radiator Hoses
Posted on: 2006/2/24 1:10
