Hey Phunk, your smartarse remarks actually helped on this one, so cheers bro!
I took the tacho out and over to the trusty parts chaser (86 'rolla) and hooked it up in a half @rsed way, by wedging the + & - into the battery terminals and holding the green wire onto the coil -ve. It worked fine, but when I went to give the throttle a blip, I got a little nip from the coil- not a full charge, just a quiet 'hello'.
The datto didn't do that when I had tried the same thing. So I got out the manual & checked the wires to the coil- turns out that they had been hooked up the wrong way round for years (or at least since before I had the car) because the red terminal was on the black (-ve) wire and the blue terminal was on the +ve. When I hooked it up I assumed that red ment + & blue meant - ve. Spun me out that it still worked with current running the wrong way through it
Anyway the tach has signal- doesn't work that well, but it does have signal.
