Re: What is that terminal on the distributor for?
Quite a regular
From Mira Loma Ca. USA
Hi there, that terminal is for a ground, it should be grounded, but not detrimental if not.
Posted on: 2006/5/22 19:57
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
From Burbank, CA
normally a ground wire hooks to that.it's not 100% but you should hook a ground wire to it.
Posted on: 2006/5/22 7:09
|||\ 81 KPB310 /|||
From Bunbury Western Australia
I have just noticed that I have a terminal on my distributor with no wire on it. The terminal is behind the vacuum advance diaphram, anybody have any ideas on what it is used for?
Posted on: 2006/5/22 6:49
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
