(1) 2 3 4 5 »
Re: Spring Rates q's
From Adelaide, Australia
As for weight,
L Series engine was 15kg heavier as a complete engine with box carbs etc.
With a heavier diff planned (Corolla KE55 diff) and battery in the boot weight should be pretty evenly distibuted.
Posted on: 2006/8/7 9:45
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From brisbane
B210sleeper - You're right re. the L series. I changed everything after fitting a ca in place of the A14. The heavier motor out front completely changed the dynamics of the car.
Matty
Posted on: 2006/8/5 0:33
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Burbank, CA
i have 200# springs in the front, it's not rough at all on good roads, but on crappy roads, it's probably too hard, the stock springs were 90#
i've messed with the damper settings, setting 3 out of 6 seems to be pretty good
if you have an L series than you need to offset something in excess of 150# or more in static weight.
Posted on: 2006/8/4 20:08
|||\ 81 KPB310 /|||
From Brisbane, Australia
sounds right to me
6kg/mm
* 2.2 (lbs per kg) = 13.2lb/mm
* 25.4 (mm per inch) = 335.28lb/in
Posted on: 2006/8/4 1:57
From Brisbane
i'm using 6kg HKS springs in mine (anyone know what that is in lbs??) i have been told 335lbs?
Posted on: 2006/8/3 14:09
Cheers for the help guys, looks like i will be getting springs early next week now. Ive ordered some 275lb springs through maddat, hopefully they fit the bill.
I would like to get the car out soon get it sorted, other than the need to get it back on the road, im sick of driving my partners auto dato and she's sick of the one car thing.
By the end of the year i would like to have done a few supersprints and maybe a collingrove hillclimb, then its time for a cage over the chrissy break and start a season in a class that suits the car.
Posted on: 2006/8/3 11:11
IPRA Build
matty wrote:
I've got Koni yellows in the front and reds in the back. Keep in mind it takes plenty of laps to find what you do and don't like. 300lb front springs to me is way too stiff but Harry found it perfect for him.
Matty
good point. there are alot of variables in suspension setup that will influence what spring rates suit your car. things like the front roll couple, front to rear roll axis, weight distribution etc. even the type of tyre you run - ie a semi slick will 'take' a higher rate than a normal road tyre.
and there's always driver preference too.
suspension setup is a black art, but a wise man told me years ago that when you're starting out (and even long after) you can do alot worse than copy what some of the class leaders are doing with their cars - if you can manage to get a peak under them that is... I kept doing that until I started to beat them, then I had to start learning for myself. And don't be afraid to experiment. Trial and error is a valid method! I made alot of errors with my setup along the way - learning what doesn't work (and why) is just as important as learning what does work.
Posted on: 2006/8/2 23:51
d'oh
Posted on: 2006/8/2 23:50
From Sydney , NSW
Hey whitesedan,
I find the L20 is not the rev machine the A series was!! I feel it is just making noise after 6500rpm and the dyno sheet confirms this However, a wise member suggested I 'use the torque luke, the torque' ) and way hey she gets going when you shift at 6000 and replant the right foot Keen to upgrade my venturies from 34 to 36mm to get her breathing better - then maybe a few more top end revs to be had !!
Hope you can get up this way for an event - good to catch up with members - especially those astute enough to install the mighty L series
Cheers
Posted on: 2006/8/2 22:55
From Geelong, Vic
coming along slowly, got half the tunnel done
engine is back out until the tunnel is finished then i can get onto wiring
got the sump done on the weekend too
new front end is in, just gotta sort out rear brake lines and all the brakes will be done
been woring about 3 hours a night after skool as its just sunk in that i need it drivable in 6 weeks(my 18th)
Posted on: 2006/8/2 13:28
(1) 2 3 4 5 »
