Re: air conditioning
That's not air conditioning, thats just the heater. This is simply a little radiator, like the one in front of the engine, but in a housing with air doors & a fan.
Check the following
1. That the engine is actually operating at the correct operating temperature.
2. That the coolant control valve is working properly. This controls the amount of hot coolant from the engine that passes through the heater, & therefore controls the temperature of the air in the cabin.
3. That the core of the heater is not blocked. Try gently back flushing it. Disconect the heater hose where it connects near the front of the engine & hold a garden hose against it. Do not give it a full blast untill you have established that water is passing through freely & even then, take it easy.
If the core is really blocked you have several choices.
1. Remove the heater, then take out the core & have a radiator specialist clean or replace it for you. It will work a treat then.
2. Replace the whole heater with another second hand assembly & hope for the best.
Posted on: 2006/8/10 14:33
Love your Datsun.
Treat it well.
From kenya,nairobi
it has no compressor. the air con is the type that uses hot and cold water from the engine. is it possible to air con system from another vehicle and which one would you recomend?
Posted on: 2006/8/10 12:59
From Wagga Wagga nsw australia
how much does it cost 2 get an air conditionning system installed in a 1200 ute??
Posted on: 2006/8/10 12:15
From Adelaide, Australia
You can get it regassed, you just have to use a different oil in your compressor and change the seals to suit the gas they use these days,
then again might already be converted and just need a regas.
Do a search, its been discussed many times.
Posted on: 2006/8/10 11:08
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
air conditioning
From kenya,nairobi
hey guys just bought a datsun 1200 ute and the air conditioning is lousy still with the original system. any suggestions out there on how to improve on this?
Posted on: 2006/8/10 11:01
