Re: 5 stud hubs
Quite a regular
From orange nsw
I didnt want to change the front brake setup but i think its becoming my only option. il have to look into the commodore brake conversion maby the vl turbo brakes are the go ive seen a few with these brakes before.
the axles cant be re drilled because it has 3 holes in it other then the ones for the studs. there is one big one for adjusting the handbrake and i think the other 2 are for removing the nuts that hold the axle in so there is no room left for any more holes.
i tried using pintara axles but they couldnt be resplined cause of the taper just before the spline.
Posted on: 2006/9/6 22:17
Re: 5 stud hubs
From Melbourne Vic
you should be able to change the stud pattern, i had it done on my hilux diff. diff shops do it all the time, its their job!
Posted on: 2006/9/6 4:15
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: 5 stud hubs
From brisbane, qld
Dont know if this helps, but, Im led to beleive you can put a commodore disk onto a stanza or bluebird front stub. Cant tell you exactly how its done, but it can be done. Im looking at doing it myself.
I know a fitter and turner who reckons he can do it fairly easily.
It will also give you a matching sized disk rotor to the back set up.
Posted on: 2006/9/6 1:18
5 stud hubs
Quite a regular
From orange nsw
Hi guys im havin a little prob with my ca conversion into a 80 model ute. its all been going sweet up until my machinest told me that he couldnt change my axles to 4 stud on my shortened down vn calais diff.
my question is there any 5 stud front hubs that i can use on the front so i can stil keep my upgraded brakes i have on the front. any help or sugestions would be great thanks.
Posted on: 2006/9/5 22:03
