Re: Any Help
From Brisbane
if you get the computer re-chipped, they can remove fuel cut, speed cut etc, i think Kev sells them for around $270 exchange, with a chip to suit, TNT, Mines etc.
what fuel system are u using?
Posted on: 2006/10/16 12:16
Re: Any Help
From SE Melbourne
I wouldn't underestimate the factory ECU - it will likely be cheaper to get someone to reflash your ECU - it will cost a bit a few hundred I would think - but a better result.
I haven't seen the 32 bit microtechs, but the 16bit ones were a little gay....
Posted on: 2006/10/16 11:06
Mildman, Datsunless
Re: Any Help
From sydney
i think it's time for microtech
Posted on: 2006/10/16 11:00
Re: Any Help
From sydney
yeah still using factory dash....
no not using fuel pressure gauge
Posted on: 2006/10/16 10:59
Re: Any Help
From Sydney, Australia
could be fuel supply, could be rev limit (3 speed + 4.11), could be speed cut.
Are you using factory dash and speed sender? Then it's speed cut.
Are you running a fuel pressure guage?
You don't tell us the revs at 350meters.
If you put it into storage for 50 years, you won't need the high speed nymore. because you'll be a grandpa driver.
Posted on: 2006/10/16 10:27
Re: Any Help
spped cut defender.... that will get rid of it and any factory fuel/boost cut out.
Posted on: 2006/10/16 10:21
Re: Any Help
From Gold Coast, Australia
not sure, thats one for the more experienced dudes to tell you. i dont even know if thats what the prob is but it makes sence right? aftermarket ECU.
Posted on: 2006/10/16 10:18
Re: Any Help
From sydney
is there a way i can get rid of that speed cut...
Posted on: 2006/10/16 9:46
Re: Any Help
if your running standard ECU it may be the JDM 180km speed cut? with the ratios it might read 180kmh before your prob even hitting 140kmh
Posted on: 2006/10/16 9:44
Any Help
From sydney
My Datsun 1200 runs out of power, before the end of 400 metres, whilst racing it at the drags.
It gets to a certain point and just comes to a hault, at 350 metres and the speedo goes off the clock.
I have CA18t , 7psi automatic 3 speed which runs a 1200 ute diff with diff ratios of 4/11.
Could anyone help me with this problem much appriciated
Posted on: 2006/10/16 9:42
