Re: Stumpy 5spd question
let me do it
Posted on: 2011/2/26 11:28
The mainstaft nut will be loose. At first it will jump out of 5th and in extreme cases dissapear.
Posted on: 2011/2/4 12:08
My datsun 1200 gear shifter locks on gear No. 2 every time i shift but when i accelerate faster i am able to shift to gear 3 or 1
Put some oil in it.
Penrite 75.
Posted on: 2011/2/4 11:12
My datsun 1200 gear shifter locks on gear No. 2 every time i shift but when i accelerate faster i am able to shift to gear 3 or 1. can any one answer this. Luaks (Kenya)
Posted on: 2011/2/4 11:10
From Adelaide. SA
Cheers, a mate is pulling it apart this weekend so some questions maybe answered... hopefully.
Will keep you posted.
Cheers. Adam.
Posted on: 2007/2/9 2:52
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Mudgee NSW Australia
Ive had a few behind my ca18det I never had any 5th gear problems although the input and cluster sheer teeth if you give it too much also slow shifting & crunchy with decent power. 2nd and 3rd gear break most often. 5th gear is normall only a cruise gear I cant see why it dosnt go in unless maybe the selector fork is broken??
once pulled appart you shoudl be able to see.
Cheers Andrew
Posted on: 2007/2/9 2:33
If In doubt run more BOOST
From Adelaide
I have a stumpy box on a ca18det and it has 5 gears, but does not like changing down into second gear at high revs, but after about 10 laps it seems to be ok. Changes great into 5th tho.
Posted on: 2007/2/9 2:11
From Adelaide. SA
Anyone, surely someone knows about these box's??
Posted on: 2007/2/8 13:02
Peter Brock
From Adelaide. SA
Nah, I pulled it from the skyline my self... Its definatly meant to be a five speed, yet it makes no noises or grinds but only has 4 forward gears.
Posted on: 2007/2/7 20:31
Peter Brock
From Brisbane
are you sure it's not a P510 (1600) 4 speed?, they run a stumpy short box
Posted on: 2007/2/7 19:38
