Re: need hhelp
From SE Melbourne
I put an A14 into my coupe last year - took some pics here:
http://mildman.datsunprojects.org/index.htm
Posted on: 2007/3/11 14:24
Mildman, Datsunless
Re: need hhelp
There is an outline in the Datsun 1200 Encyclopedia: Engine Swaps. Click the links and pictures related to A14 swaps.
It is very nearly a bolt-in. If you get the exhaust out of the A14 car, that might bolt in as well (it did for me, sedan-to-sedan).
Posted on: 2007/3/11 13:19
Re: need hhelp
From Bunbury Western Australia
no not much just exhaust needs to be upgraded, engine mount adapter bars, some ange iron will do, just cut two 6 inch lengths and sit the engine in the bay bolted to your box then while the engine weight is supported by the lifting tackle just measure the distance between the mounts and crossmember then drill holes in the angle iron accordingly and bolt the angle iron to the mounts and the crossmember, easy job mate don't stress too much
Posted on: 2007/3/11 12:51
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
need hhelp
Not too shy to talk
From LOS ANGELES
Hello guys i need help im putting an a14 in my coupe do i need to make any modifications thanks.
Posted on: 2007/3/11 3:48
