Re: How does the A-series oiling system work plz?
Thats coming up next week.
Posted on: 2007/3/26 10:40
Love your Datsun.
Treat it well.
Not too shy to talk
Yip,the Haynes manual, although vague also seems to indicate the dizzy side.
Can't be that critical eh? Otherwise Mildman might have posted something to the effect of: "the mystery of the prematurely worn out rocker shaft"
Posted on: 2007/3/26 6:07
From Adelaide, Australia
Definitely the distributor side.
Posted on: 2007/3/26 5:50
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From South Africa, Bloemfontein
As far as I know it must be on the distributor's side.
Posted on: 2007/3/26 5:29
1977 Datsun 1200GX
Not too shy to talk
Hey guys - just to make absolutely sure (I'm gonna start the thing tonight after work) : The headbolt marked "T" goes into the middle hole on the dizzy side of the head?
The reason for asking is that I discovered Mildman's A14-build thread and while cross checking my build with his,I noticed that his "T" bolt went into the middle hole on the Exhaust (opposite) side of the head!
This had me slightly confused to say the least
Posted on: 2007/3/26 5:04
From Brisbane, Australia
one thing that's not mentioned in this thread, or the article dd linked is that the oil to the head is supplied via the centre cam journal. the centre cam bearing has extra oil holes to pass the oil and the centre cam journal has a scallop cut in it that restricts oil supply to the head.
Sports1300 racers (clubmans) used to elongate & deepen this scallop to increase oil supply to the valvetrain, used in conjunction with a hi-vol pump made from L series internals.
Posted on: 2007/3/19 20:44
New cam? Don't forget to break it in (do not let the engine idle). See camshaft.
For more on the oiling system, see Lubrication Circuit
Posted on: 2007/3/19 14:05
Not too shy to talk
Thanks Dodgeman for the thorough explanation
Posted on: 2007/3/19 10:55
Not too shy to talk
I've kept it simple as I'm unfamiliar with Datto motors - Stock A15 with new rings on (good)used pistons,hone and new bearings.
The head has been flowed and reconditioned by a mate in the trade(stock valves,recut seats,new guides). The head has been skimmed to get the CR up to a modest 10.5:1. It has a 268 deg cam and twin 40 Weber sidies.
I'll build a warmer version next time around
Posted on: 2007/3/19 10:38
Hi Mustard
Are'nt you going to use this car/engine for classic racing?
If so, what have you done to the engine.
Just curious about what the racers do to their engines to get good reliable power.
Regards
Posted on: 2007/3/19 10:29
1977 Datsun 1200GX
