Re: stanza strut & brake conversion
Posted on: 2007/4/30 6:09
From Toowoomba Q Australia
I've seen 1200 utes with those wheels on but I also think that it's not a simple bolt on and go. I think they might be just a smidge too wide. You can also google "jaw 120y" or "stanza into 120y". That site may be of some help with what bits to use where and why. Good luck lets know how you go !
Posted on: 2007/4/30 3:03
thanx mate.
Posted on: 2007/4/30 0:30
From Everywhere, mostly Melb/Geelong/Ballarat
Hey,
Just in case it helps, I used 120y radius rods for the same conversion in my coupe. Worked no problems and everything seems fine. I'm only running 14s though.
Posted on: 2007/4/29 23:55
Can someone help.
Have got complete stanza struts & brakes to put in 1200 ute.
but have been told different stories,i read the tech section & it said to use 120y radius rods & sway bar.
someone else said no,use sunny tension rods.
someone else said I have to have ones made, so I can get adjustment.
(wanting to fit trx wheels.195/50/15
Posted on: 2007/4/29 21:22
