Re: Body Lift / need two leaf springs
From Redmond, OR
Just to let you all know , a 4ft leaf spring cut in half is all I needed to lift the back of my ride. Lifted it 1-1/2 inches. It also rides better, and handles better.
Thanks for all your help, NOT
Posted on: 2007/5/31 13:51
Here is my motto: I may be getting older but I refuse to grow up
From Redmond, OR
To do what I want I need two more leaf springs(matching). Does anyone have a couple laying around from a lowering job?
Posted on: 2007/5/23 5:46
Re: Body Lift back end only
From Burbank, CA
oh. so these are original leafs...
i know nothing about leaf springs ;)
Posted on: 2007/5/22 6:02
|||\ 81 KPB310 /|||
From Redmond, OR
the back is leaf spring, and no I did not do anything to the rear. that is the way I got the car. Just want the body to sit above the tire
Posted on: 2007/5/22 5:00
From Burbank, CA
hmmm want tot trade springs? i'd like to be lower in the back.
is it a leaf spring car? if so it's pretty cheap and easy to do.
if it's coil springs, less weight in the back? how did you lower the back, or didn't you...
Posted on: 2007/5/22 3:17
|||\ 81 KPB310 /|||
From Redmond, OR
Hello from the U.S. need to know the best and easyest way to lift the back of my 210.
Just put 205/60/13 all the way around, and the way the car sits it still makes the back wheels look small. I want to be able to see the whole tire from the side. Only want about a 1"to 1.5"
The front is already droped 3". What should I do?
Posted on: 2007/5/22 2:58
