Re: BLOWN AND INJECTED A12 on ebay!!!!!
From Christchurch NZ
Perhaps you could make a powerbulge to hide the goodies.
Posted on: 2007/10/11 8:19
Forced Induction!
From sydney
I imagine that it would be worth every penny of the 5g that he is asking for it, but its a pity that it need methanol to run. If it was pump fuel, you could almost use it to the milk in the morning
Maybe with a bit less boost it might run on pump gas?
If it fit under the hood I think he would have buyers lined up round the block.
Posted on: 2007/9/30 23:39
Dundee1000 wrote:
the BOV is on the pressure side b4 the throttles.. where it should be...
Ahhh, silly me, I should have looked. I simply assumed that the induction was throttled on the intake side of the blower. If that had been true, then it would not need a BOV. Durrrr.
Posted on: 2007/9/30 14:13
Love your Datsun.
Treat it well.
From Coondle, WA Australia
Pigdog you are right
in reality its a wild engine that hapens to to have a car wrapped around it.
And yeah its needs a Mr Gasket on top just to finish it off.
Posted on: 2007/9/30 13:32
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Brisbane
If only all that could be squeezed under the bonnet!!... looks hot...I wonder on the HP figures.
Posted on: 2007/9/30 13:09
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Geelong, Vic
it was lucky that the pic of the front didnt load in the ebay ad, it gave me enough time to read the specs and think it was cool
but to me its just a mad engine with crappy drivetrain and body
Posted on: 2007/9/30 13:08
From Freo
it is some pretty serious gear..
it should tour the states so we can all experience it..
Posted on: 2007/9/30 12:55
A15 PSI Project Motor
'72 CB750k,
Holy crap, did you read the specs on this thing. Full crank girdle, 3 amp magneto, 'O' ring block etc etc.
At 30psi of boost, what do you need an A15 for. Hell, it wouldn't even need porting.
This would be the most serious A series that I have ever seen, but surely that isn't a BOV on the outlet pipe is it.
With Methanol [Alky] as a fuel it isn't really your average grocery getter.
THE SPEC'S
Nissan A12 Supercharged, hilborn style constant flow injection, on methanol.
Features, crank girdle, custom rods, aries forged dished floating pistons with teflon buttons
Inside of block deburred, good balance job, dry sump, oringed block and followers in cylinder head
Extensive port work + ram tubes fitted, bigger valves, chambers cc'd, appropriate rocker gear for blower style solid cam
3amp magneto, eaton m90 supercharger(of a v6 mustang) runs 30 psi boost.
Posted on: 2007/9/30 12:21
Love your Datsun.
Treat it well.
From Geelong, Vic
i saw this on ebay and was going to post it on here till i saw the front pic of the car, kinda ruined it for me
Posted on: 2007/9/30 11:33
From Castro Valley,CA USA
All it needs now is one of these
stacked on top with an elbo off the back to feed the blower.
Even if it was on a stock A12, that supercharger just looks crazy. I love it.
Posted on: 2007/9/30 6:42
