Re: UTE RIMS
From Adelaide, Australia
I have had pintara wheels on my 1200 with drum struts (which should be same offset as the 120y struts). I just used a 3mm spacer and due to having 3
Posted on: 2008/1/30 9:00
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: UTE RIMS
From brisbane, qld
The chaser style rims you speak of will generally have a positive offset. This means they wont fit on the front, right?
You may have trouble finding something 'stock' to fit on to suit the 120y set up and also match the rear rims.
You could possibly consider modifying the same type of rim by having the centre removed and then moved towards the inside edge and rewelded thus providing a more negative offset to clear the strut.
Otherwise you will have to consider a mismatched rim combo, which may be a pain in the bum depending on the rim diameter.
Posted on: 2008/1/30 8:42
Re: UTE RIMS
Quite a regular
From Middle Of Australia
After same info. but want new white rims I'm thinking.
Any suggestion on brands or bussiness'.
Need right offset and that about it.
Sorry for the highjack
Poster: sunny Date: 2007/4/7 23:40:48
we could round up all the 1200 utes that no one wants and send them to the states.
done the round up, sorry no unwanted ones here.
1200 Ute Project-CA18DET
Re: UTE RIMS
Get you some wheels from a 120Y -- they will fit.
Posted on: 2008/1/30 5:53
UTE RIMS
UTE RIMS need to no what rims will fit on 1200 ute with 120y front (silverbrakes)
rear is r31 diff changed to 4 stud stock looking rims (chaiser style) thanks everyone
Posted on: 2008/1/30 5:37
