Re: Landcruiser brake conversion caliper orientation?
THanks 3 rotor!
That's what I was looking for.
I had concluded the same thing but wanted some reinforcement.
Although it seems from R-fast's experience it doesn't make that much of a difference.
Posted on: 2008/6/11 9:05
From South Africa
Nice!!! yes...
Posted on: 2008/6/11 8:44
From Melbourne, Australia
this is my first lot... and they are correct from all comments
Posted on: 2008/6/11 8:33
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From South Africa
The reasoning behind the difference in the pot-sizes is to prevent the leading edge of the pad, getting eaten away faster than the trailing edge, looked at it from the direction of rotation of the rotor.
To do this they made the leading pots small and then going bigger towards the back...
http://www.apracing.com/drawings/cp4340_1cd.pdf
so to conclude, it is possible to mount a stock trailing caliper in front of the axle by moving it over to the opposing wheel, and still have the bleed outlet at the top. The important part is not whether it's in front or behind the axle, it's the direction of rotation.... and always the smallest piston should see the rotor first.
Posted on: 2008/6/11 8:30
Thanks guys.
And it's no street car! I was going through a pair of pads per track day with the 240K brakes so this was a necessary upgrade.
Posted on: 2008/6/11 8:01
From Sydney , NSW
Front mount for me - works fine and no chance of fouling any steering components.
Oh and they STOP!!
Will be more than enough for a street car - pad choice is limited but that's about it.
Cheers
Posted on: 2008/6/11 7:57
All torque, no traction
A division of "My mate's ....." engineering
From Canberra
yeh its to create an even bite on the pads, to stop them wearing unevenly. I think if you orient them so the bleeders are at the top (as they should be) then the pistons will be where they should be.
Posted on: 2008/6/11 5:35
Thanks guys,
I found a couple of pics of the calipers on the original landcruiser and they are mounted on the back on them too. I swapped my struts around and did it that way, I'm sure Mr Toyota did it that way for a reason.
Posted on: 2008/6/11 5:27
mine are on the rear of the strut too but not for any particular reason
Posted on: 2008/6/11 3:25
1200 Coupe Rallycar
From Melbourne,Australia
Hey mate my calipers are mounted to the rear if that makes sense closer to the back of the car. I also had to grind a small section out of the brake pads to stop them from touching the hub part of the discs
Posted on: 2008/6/11 2:19
