Re: help please... whats needed to convert to efi turbo...
From South Africa
here is a list of all the stuff I need for a complete build....
Note, it does not include the distributor mod, if yours is still points, probably be best to get an electronic dizzy.
The List.
main tube 1
runners Al inlet 4
injector pods 8
Tube endcaps 2
welding 20
inlet manifold flange 2
Runners 304SS Inlet 4
silicone rubbers 38mm 4
clamps 38mm T 8
fuel rail 1
Banjo + Bolt 1
T-body 63mm (76mm od) 1
exhaust flange 10mm MS 1
steam bends 42mm MS 16
turbo flange 10mm MS 1
downpipe flange 10mm MS 1
Boost Plumbing 304SS 1
Boost Gauge 1.5bar 1
Fuel Pressure Regulator 1
injectors 440cc (set) CA18DE 1
injector plugs 4
intercooler 1
fuelpump inline 1
Turbo gt1548 Garrett 1
Fuel hose 6
Fuel filter 1
Gotech MX ECU 1
Basic blow off valve 1
vacuum fittings 3
clamps endcap red 10
clamps 50mm T 4
clamps 63mm T 2
clamps 80mm T 1
vacuum Tube PPRE 6
vacuum T push 1
silicone rubbers 50mm 1
silicone rubber 50to63mm 1
silicone rubbers 63to76mm 1
Gasket Turbine inlet 1
Gasket Turbine out 1
Gasket exhaust 1
Ceramic coating Mnfld 1
Powdercoating 1
Posted on: 2008/6/30 10:28
dunno who owns it, is for sale though, in sydney area.. i say nothing like a good road trip..
although at the same time i can hear my girlfriend sayin "if your gunna get another car get something with 4 doors and aircon"
Posted on: 2008/6/30 0:49
From Brisvegas, oz
ooooh who owns it have you got any pics?
Posted on: 2008/6/30 0:13
www.camerasplus.com.au
im going to brissy in a weeks time, the thing is i can drive back a 8000 dollar 1200 ute that has an efi a14 turbo in it...
thats what im thinking about, then just leave mine as a daily
Posted on: 2008/6/29 23:55
From Brisvegas, oz
sorry i didnt get back to you the other night gillie my phones text buttons are fuked. you will also need a lift pump. i would say you might be able to get it for 5 grand in oz for new stuff if your lucky plus tuning.
Posted on: 2008/6/29 23:53
From South Africa
wow is 8 Grand a fair price for a complete setup?
I'm costing the setup I'm busy building right now, And I can pull it through with everything brand new, new turbo, new 440cc injectors, new T-Body new intercooler, New ECU...etc,etc well basically 100% new....
all for less than $US5000 effort included.
Posted on: 2008/6/29 18:10
hmm ok.. ive heard that the 13b cas does the trick with a change over of the drive gear..
then i suppose that way ignition timing would be able to be controlled better
Posted on: 2008/6/29 15:19
From Darwin NT
probably be better off trying to get a fuel and spark computer then using ford edis to control the spark
Posted on: 2008/6/29 10:12
current project 4x4 patrol...
got a cooler, tb on the manifolds, wiring come with computer, fuel only ecu,
Posted on: 2008/6/29 9:56
From Darwin NT
intercooler, throttle body, all the wiring, different distributer, oil return line to sump, and a few different sensors
all these parts can be purchased cheaply if you know where to look
Posted on: 2008/6/29 9:47
