Re: A-Series Engine
Bored indeed, been sitting around for so long waiting for a particular someone to work on it.
Thankyou all.
Posted on: 2008/7/30 4:02
Re: A-Series Engine
clyons8 wrote:
I've just finished re-building my bored A14.
Why is it bored? Isn't there anything for it to do?
If the oil pressure light works that is a good indicator that the oil pump is working but during crank I would expect to see very little oil at the rockers. It won't hurt to do the first start with the rocker cover off or even chop the top off a spare one.
Posted on: 2008/7/29 9:46
Re: A-Series Engine
From Adelaide, Australia
What head are you using and what brand headgasket... some nissan a-series gaskets are head specific and will not fit universally as other brand gaskets do.
Posted on: 2008/7/29 9:26
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
A-Series Engine
I have had the rocker cover off to sort my timing out and I have been turning the engine over without spark to check that everything is operating as it should.
I didn't see any oil moving from the rocker shaft assembly and I would have expected to see at least some lubricating at cranking speed.
Can anyone confirm whether the A series does have visible lubrication along the rocker shaft assembly during cranking speeds?
I can't remember seeing oil on my A10 in my old datsun even when it was idleing.
I have primed the pump (filling the oil filter).
Any help would be great.
Chris
Posted on: 2008/7/29 7:00
