Re: Watery Oil leaking from the Crank Case
From Perth WA
yes, oil and water jackets are close together in head, little corrosion from tap water causes them to mix.
Posted on: 2008/7/31 5:38
From Aust
Id still advise its head related.
If you remove the crank case is it all milky and gunky.....
If so id be leaning towards putting a new head gasket in, resurfaceing the head and preasure testing the head.
Thats my advise.
Good luck
Cheers
Posted on: 2008/7/31 4:21
Not too shy to talk
From Gracemere QLD
has been using some water but i have a slow leak in the radiator that i have to replace and the water is a grey like colour?
Posted on: 2008/7/31 4:17
From Aust
Browny / rusty looking water.....
Has it been using alot of water???
Posted on: 2008/7/31 4:14
Not too shy to talk
From Gracemere QLD
When you pull the dip stick out the oil looks fine but i have been using tap water in the radiator?
it is hard to start it is also playing up as in it will be fine for quiet a while then all of a sudden it will not rev properly you have to hold it flat strap to make it go and when you take of you have to put you foot to the floor to make it take off otherwise it just dies down and you have to hold it flat to make it slowly pic up.
THanks
Jon
Posted on: 2008/7/31 4:11
From Aust
Condensation will only go milky around the oil filler cap not through out the whole crank case.
Sounds like a blown head gasket. Have you been loosing coolant lately??
When you say the car has been playing up does this mean a miss when you start it up or hard to start?
This is something that needs attention straight away or you will do more damage to the motor.
Cheers
Posted on: 2008/7/31 4:10
From Melbourne, Australia
could just be condensation
maybe worth draining your sump to see how much is like that
Posted on: 2008/7/31 3:54
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth WA
pull out the dipstick and look also. sounds like coolant is getting into the oil. most likely place is around head gasket. Have u overheated it and maybe warped the head recently? do u use tapwater instead of coolant? these alluminium heads corrode easily if u use plain water.
Posted on: 2008/7/31 3:53
Not too shy to talk
From Gracemere QLD
i have what looks like watery oil/fuel that is coming out of the crank case vent.
i am wondering if this is normal it is kind of a grey coulour substance thats thin like water. if it is not normal can anyone help with what mite be causing this. the car has been playing up recently and just wondering if this is one of the systems of something bad.
Thanks
Jon
Posted on: 2008/7/31 3:43
