(1) 2 3 4 5 »
Re: This is the look I want!
From The garage, NZ
as in not try suck my wang over the enet and do it properly
Anyway, good luck with it. Theres a sevear lack of good wheel fitment on 1200's from what im seeing in australasia. Mine could be a hell of a lot better myself
Posted on: 2008/10/14 21:27
From Wagga Wagga, NSW
cheater_5 wrote:
p.s. #### jake your a nob sucker, when you just going to buy a plan ticket so you can come here and do the job properly
In english please donut puncher?
What do you mean do the job properly fool! im doin just fine over here
p.s pooooooftttterr
Posted on: 2008/10/14 7:27
From Melbourne, Oz
Hav a milde a15 that will get hoter but remain N/A and wont run flairs, hav some chevoits with semi slick for when I want more grip.
Posted on: 2008/10/14 7:11
"I hav achieved wood"
From The garage, NZ
sounds good to me. Good tyre sizes are 155/60, 165/55, 165/60, 175/50, 175/60, 185/50 etc etc etc. Like the 175/50 because it doesnt buldge over the edge of a 7, is lower profile, comes in a few really performance orientated tyres and is still small and costs little (compared to larger).
But 165/155's are where its at.... if you dont have lots of power, then i recommend the 185/50's or even wider depending on availability, how much power you actually have and if you're going to run flares.
On the street, small tyres are sweet. Obviously not a lot of grip with lots of power
Posted on: 2008/10/14 7:05
From Melbourne, Oz
Thank's Heap's cheater!
I'm thinking 13x6.5 -10ish with the lowest profile tire I can finde and siting on it's gut's and a fair bit of camber
Posted on: 2008/10/14 6:56
From The garage, NZ
jebus that was a novel
stance is everything
p.s. #### jake your a nob sucker, when you just going to buy a plane ticket so you can come here and do the job properly
Posted on: 2008/10/14 6:09
From The garage, NZ
yea -7
That offset calculator is good for ease of working out fitment but really you can make anything fit. If you look at works1200's old sedan which had 13x7 with a zero offset his wheels poke a sh*t load more than mine which made for awsome wheel fitment. He was running ae86 suspension etc which pushed the track out heaps. Kinda like running a very low offset with lots of camber dialed in.
Obviously ride height, tyre profile, wheel offset and camber setting has a lot to do with good wheel fitment like any other car out there.
As far as offset is concerned, with standard spring perches and with a half decent ride height, i found that a 0 offset on a 13x7 is pretty close to the most positive offset you'll want to run. Could probably get away with +4 or so but anymore than that and you'll be rubbing the perch. This is all taking into account that the tyres arnt ballooning over the rim.
Heres a picture of the inner of the rim clearance to the strut. As you can see, theres sufficient clearance but not tooo much to play with, i think about 10mm from memory.175/50/13 tyres
Theres quite a bit of room to play with on a b110 in the front. On my ute the lip is level with the tyre and i havent rolled the gaurd at all. Just bent up the inner lip so it doesnt cut into the tyre if it does so and added some camber. Never rubbed.
On the rear ive pretty much done the same but with a little bit of a push on it because my rear is very soft for some grip.
If you're looking at 14's you have to realise that itll be a bit more work to get the car sitting at a nice height because of the larger rolling diameter, dependent on tyre size ofcourse.
IMO i would always start with a rim/offset i want then go about fitting it. With the right height/spring stiffness, tyres, camber wou'll be on your way to an awsome stance.
If you ran 14x6's, to get the same poke as the 13x7's you'd need a -20 offset but will have 26mm more clearance to the strut. If you wanted an 8inch wide rim the same poke you'd need a +6 offset but then would have 26mm less clearance to the strut meaning you'd have to add spacers (same as reducing offset without added dish/taper) to gain some clearance and would end up with something like a -15 offset to clear but will poke another 21mm.
So if it were me and i wanted to run 6's then id find the most negative offset i could and make em fit. If i wanted to run 7's, well id do the same really but something in the 0 to -10 would suffice.
These are all my opinions, dont get cut up about em.
Posted on: 2008/10/14 6:08
From Darwin NT
heres something helpfull
wheel offset calculator
Posted on: 2008/10/14 5:31
current project 4x4 patrol...
From cranbourne, vic
16mm and about 10mm side wall clearence.Quote:
ROConnor wrote:
how much room from the rim to the strut on the front?
Thank's, Connor.
Posted on: 2008/10/13 12:04
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Melbourne, Oz
Thank's, Connor.
Posted on: 2008/10/13 11:49
(1) 2 3 4 5 »
