Re: Oil Pump
Better still, determine the actual cause of the leak, purchase whatever repair parts that are needed, & fix it properly.
The oil pump hes never really been a problem area with 1200's so try niping up the bolts that secure it to the engine first.
If necessary, pop down to your Nissan dealer & order the gasket between the pump & the block & replace it if this is where the leak is.
The A series engine isn't OLD, in fact production of it for road vehicle use was discontinued only at the end of 2007 & as far as I know, it's still produced for industrial applications.
Posted on: 2008/8/26 4:48
Love your Datsun.
Treat it well.
Re: Oil Pump
Not too shy to talk
From Hobart, TAS, Oz
Between you and me and eveyone else that will read this, I haven't got a clue either about an electronic change! I think I'm suffering some old-engine paranoia.
I think I might be better off having a good chew on some PK and applying liberally to the offending area.
I can't imagine it myself.
K
Posted on: 2008/8/26 4:44
Re: Oil Pump
Your oil pump has a pinhole sized leak & rather than fix it you want to do an electric oil pump conversion?
I have no idea what an 'electronic' conversion would be.
Now that's cutting edge as I don't think that anybody else in the world has thought of that.
Our Datsun A series engines have been around now for about 42 years with millions made & used all over the world &, with the possible exception of some sort of extreme race engine, nobody runs an electric oil pump.
Ever wonder why?
Posted on: 2008/8/26 4:38
Love your Datsun.
Treat it well.
Oil Pump
Not too shy to talk
Well, the oil pump on the A12 has decided to give itself a pinhole size leak, which over a couple of days becomes noticeable on your driveway.
Any thoughts about an electronic pump as a replacement? Is this a job that I'll have to get the pros in on?
K
Posted on: 2008/8/26 4:30
