Re: manifold questions
From The garage, NZ
never seen one of those before either and ive had apart standard early a12's through to a15's wierd
Posted on: 2008/10/1 22:02
From northern 'burbs adelaide
i think its to warm the mixture up against the bottom of the manifold
Posted on: 2008/10/1 21:49
From Townsville, Qld
Well I'll be danged, none of mine have that. What it does though is allow the mixture to speed up before it's mixed and distributed to the cylinders, I would like to make a tube suitable for my 32\36
Posted on: 2008/10/1 12:15
here what the original one looks like
Posted on: 2008/10/1 11:01
she's manual choke mate
Posted on: 2008/10/1 10:44
From Charlotte NC USA
make sure two things are true
1. you have power and ground at the choke
2. that the choke is adjusted correctly
Posted on: 2008/9/30 23:23
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
well starting cold has gone out the door and it runs like a bag of s**t now. but as for fuel economy i'm getting the best i've had since i bought the car. ah well a ca will fit in there quite nicely soon enough
Posted on: 2008/9/30 21:50
Yes, that will change the performance ... for the worse. You won't notice much change though, more likely to notice your fuel costs go up a bit.
Posted on: 2008/9/30 3:52
its under a stock carby ... ill post a pic up tonight
Posted on: 2008/9/29 21:52
Aluminium pipe??!?
I know what you're talking about but I haven't ever seen one with an aluminium pipe. If I recall you were after a stock carby.
I wouldn't expect any power loss.
Maybe pop up a picture.
Posted on: 2008/9/29 8:58
