(1) 2 3 »
Re: a series roller rockers on ebay aus
From Darwin NT
and i bought it sight unseen
and just checked there website you do need custom pushrods
aww well theyll look god on the motor for awhile till i get some new ones machined
Posted on: 2009/2/2 22:14
current project 4x4 patrol...
Check up Brent. You may have been misled.
How much did you score that steering wheel for?
Posted on: 2009/2/2 22:07
From Darwin NT
dman i have been led to believe that these were bolt on and you did not need custom pushrods?
Posted on: 2009/2/2 19:53
From Perth
The seller thinks they are 1.55's
I don't need these... but they are cheaper than I've ever paid for them
Posted on: 2009/2/2 14:01
dazza1200 wrote:
polish the stockers and shot pein them
heaps lighter!
Shot peining them does not make them lighter but may marginally improve the strength.
Polishing also, of itself, does not add lightness [???] however removing material from the rockers in the right places before the other processes will reduce the weight fractionally, but does nothing about the rocker arm ratio or the friction & resultant lateral loading of the valve in its guide during the valve opening phase.
The true roller rockers are lighter by virtue of their alloy construction.
They also have less frictional drag on the shaft by virtue of the needle roller bearing at this point.
They are also made with a higher lift ratio than stock rockers so you get a little more lift at the valve without changing cams.
The roller tip virtually eliminates the friction &drag across the face of the valve stem so valve guide wear is reduced [in an exact comparison with stock rockers] & a tiny bit more friction is eliminated at this point.
Lets summarise.
Roller rockers offer lower rocker arm weight without compromisung strength, they reduce friction at two important points, they reduce side loading on the valve thereby increasing valve & guide life & finally they need less oil to provide proper lubrication.
On the downside is the price, particularly when you include the custom pushrods that will be required. For a new instalation, all inclusive, you had better have $1,000 or more in your pocket.
Posted on: 2009/2/2 12:57
Love your Datsun.
Treat it well.
From Melbourne vic
lots i hope
Posted on: 2009/2/2 10:59
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Brisvegas, oz
im going to bprojects in 1 week yay. so im just adding up what im buying whilst there
Posted on: 2009/2/2 10:58
www.camerasplus.com.au
From Melbourne vic
Yeah at high rpm the rockers can walk off
the valves with the standard springs, so
they make spacers it's not for weight
reasons.
:Nice
From Freo
they replace the spring and stop the rockers "floating up the shaft" at high RPM..
(I'm doing an order in the next few days)..
Posted on: 2009/2/2 10:57
A15 PSI Project Motor
'72 CB750k,
From Brisvegas, oz
how do the spacers effect it are they just lighter. do they just replece the spring inbetween the standard rocker
Posted on: 2009/2/2 10:52
(1) 2 3 »
