Re: A15 race pistons? who sells.
From South Africa
if its between the 2 rings its usualy ring bind (if the car is tuned right and not getting ring flutter from detonation),,, you use a ring file and gap them to a suitable gap per your requirements
Posted on: 2009/3/14 8:05
From Melbourne, Oz
do you do this in a lathe? and how much? because both times I hav crack'd them Its be'n the lip between the two compresion rings were it has crack'd?
Cheer's
Posted on: 2009/3/14 7:55
"I hav achieved wood"
From South Africa
Your biggest thing is to find a piston with oiling holes not slots, those slots weaken the landings. Your next thing is to open the ring gaps, your normal off shelf pistons were never spec'd to rev very high or be used in a setup with lots of compression/combustion pressure so you want to open your ring gap a little to prevent ring bind which also cracks the landings off due to the incredible drag created by a bound ring.
Posted on: 2009/3/14 6:41
From Melbourne, Oz
B6 or E3 pistons
I'c crack two setsof piston's but they were just whatever I was given at the parts store. what are the diferance's??
Posted on: 2009/3/14 6:22
From South Africa
I have 4mm valve clearance at minimum and an adjustable cam gear and timing cover with removable window to make the best of the setup once its complete.
My problem is/was valve spring seat pressure, it is to soft, busy machining up some titanium lower spring seats 2mm thicker than stock.
FYI, CP and JE charge almost half the price of the pitroad or Kameari to make sets of one off forged pistons. tough im going to try stay away from forged if I can. I have my hands on a set of B6 pistons, will try them in my spare block
Posted on: 2009/3/14 6:04
From Christchurch NZ
Did you measure your piston to valve clearance when you assembled your engine?
Also without a cam card, I don't see how you could have properly dilaed in your camshaft either. Perhaps at those revs the piston was starting to catch the ex valve as it was chasing it shut?
Posted on: 2009/3/13 20:51
Forced Induction!
From South Africa
Some amazing prices coming up, My 800hp GTR's pistons are 30% cheaper! , looks like ill go back to using good (OE) B6 or E3 pistons, i could buy and build 3 motors for the price of one set of forged pistons,,, that said forged isnt ideal in a NA motor anyway do to a larger expansion/contraction rate (up till a certain power level obviously)
Posted on: 2009/3/13 17:17
From newcastle, NSW
i was quoted $1400AU a couple of years ago for custom forgied slugs to suit a A-14. Price may have changed since then?
Posted on: 2009/3/13 9:46
From Perth WA AUS
Yeah go with Dundee, good prices & service.
Posted on: 2009/3/13 6:43
Datsun 1200 2Dr sedan.
From South Africa
Leda have a very poor reputation here,
Will give Dundee a PM also Paeco industries.
Thanks guys
Posted on: 2009/3/13 3:55
