Re: brake conversion and master cylinder?
You also get higher pressure at the other end if you push harder with your foot.
The problem with small diameter is you have to press the pedal farther to activate the brakes. That means it takes longer to react.
It's all a tradeoff.
Posted on: 2009/3/21 5:47
From ipswich
isnt smaller better? as you get a higher pressure at the other end
Posted on: 2009/3/21 5:17
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Bigger is better, but harder to push down on - you get quicker acting brakes and a firmer pedal.
Also if you are not using a proportioning valve (like most auto manufacturers) then the relative sizes of cylinders and brakes "balance" the braking system. So using a different master cylinder causes the balance to be off.
Posted on: 2009/3/21 4:58
From northern 'burbs adelaide
7/16 is a really small master! ... im only running the s13 fronts and drum rear so we will see how it goes ... might try and get the 7/8 master. the car also has non-power assisted brakes
Posted on: 2009/3/21 1:41
From Melbourne ( West )
I have done some asking around as I am going to run S13 front disks and calipers and R31 rear.
they've said to use a 7/16 master.
Posted on: 2009/3/20 21:55
'78 Ute CA18det Project
No matter where you go... There you are
From Adelaide
You will need about a 7/8 inch master, and will have to use an adjustable bias valve in the rear line.
Posted on: 2009/3/20 20:44
From malta
bigger for sure. as piggy dog is trying some master cylinders, it turned out that s13 master lock up the back on any type of hard breaking he is now going to try r33 and will se what he says.
Posted on: 2009/3/20 17:52
im about to go the s13 brake upgrade but want to know wether a 11/16 master will be enough. i got a new one in at the local supplier but forgot to ask for the bigger one lol. will this be enough or will i need bigger?
Posted on: 2009/3/20 12:44
