Re: How much to rebuild a 60 series 5 speed?
synchro's are $105 each from nissan, bearing should cost no more than $120 or if you replace the layshaft bearings another $50. There are some problems the 60 series suffer from like case hardening coming off and breaking the spline under the 4/5 selector circlip.
Posted on: 2009/7/2 11:14
From brisbane
Thanks guys
I won't be rebuilding it myself as I have neither the skills or time.
Looks like it shouldn't hurt the wallet too badly.
Thanks again Matty
Posted on: 2009/7/2 7:48
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From sydney australia
If you've rebuilt gearboxes before the cost is mainly in getting the bearings. There's also a lock nut at the back of the main shaft that can either be replaced or machined slightly to get a new lock in section. Last time I got bearings it was about $100, but that was a few years ago. Any diff & transmission place should not have any problems, either, unless they're incompetent. With the broken shifter pin, take those along & see if you can get some stronger pins. I've broken a few over the years & my friend who rebuilds them for me always puts something stronger in.
Posted on: 2009/7/2 2:38
From Geelong, Vic
ive pulled apart my own dogleg 5 speed (was a 63L though) and its nothing to hard to do. and if your just replacing all the bearings then its nothing that cant be done with a few general tools and a press
also replaced all the main bearings and one of the needle roller bearings in my r31 box and it cost me $140 in bearings and a bit of my time
Posted on: 2009/7/1 1:35
From brisbane
Hi all
I have a dogleg 60 series 5 speed that needs rebuilding.
I had it in the car and noticed 2nd and 3rd gear synchros were tired but other than that it seemed pretty good. I have since removed the box as a roll pin came loose meaning I was unable to select either 2nd or 3rd gears.
Has anyone had a 5 speed box rebuilt?
What sort of money am I looking at?
Any recommendations for someone in Brisbane to do the job?
Cheers Matty
Posted on: 2009/7/1 1:17
