Re: Ca18det SPLITFIRE IGNITION
From brisbane
Hi Bruce
I just sent you an email with the codes.
Regards Matty
Posted on: 2009/8/12 13:32
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Guys,
I am in the US running a CA18det in my 1990 240sx I'm interested in the splitfire ignition can you tell me what part number your using on your Ca18dets thanks my email is dbody1@netzero.com
Bruce
Posted on: 2009/7/30 21:59
Re: Ca18det SPITFIRE IGNITION
From perth
ls1 coils are good on ca/sr's
Posted on: 2009/7/17 12:47
From South Africa
"Splitfire"
They are good, but as said they are more a cheap replacement for old fried OE units. Just about all the 300+kw SR20's I do the Splitfires are in the quote because 95% of the OE coils that at 10+ years old will not give a clean burn at 1.5bar+
Posted on: 2009/7/17 9:23
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Adelaide
I got rid of the stock coil packs and now run 4 bosch coil packs, there bout 50bucks each, and buy 4 great coil leads.
One of the coil packs can run a AU falcon there that strong..
http://www.nissansilvia.com/forums/index.php?showtopic=192432
there all done.. shows you even how to modify the stock loom..
Posted on: 2009/7/17 9:11
Go Hard Or Go Home.........
Say Hi To Ya Mum For Me....
From Sydney, Australia
I'd agree with Matty.
It's more about getting reasonably priced (reliable) replacements. It's not a performance upgrade. New Nissan ones would be AU$1000+.
I've had several old Nissan coils fail, using second hand ones rarely ends up a success. And any mechanic that would look at ignition problems will blame the coils and coil harness first.
I'd also consider modifying the harness to run more generic Bosch coils (~$70 each) and spark leads.
Makes coil failures not cause heart failure.
Can you also Change the title to read SPLITFIRE Thanks.
Posted on: 2009/7/17 9:01
From brisbane
Hi mate
I recently fitted them.
I haven't noticed a difference at 15psi from the factory coils but I haven't had much opportunity to drive lately.
The main reason why I purchased them over the cheaper aftermarket options was the fact that they come with a new coilpack harness.
I have three factory harnesses and every one of the has cracked connectors from 20 years of heat exposure.
Matty
Posted on: 2009/7/17 7:55
Can anyone give a good report or the Splitfire direct ignition systems for a ca18det?
Is it a more reliable set of coilpacks or do they just have a higher output?
Is it worth the pice tag 300-550?
Cheers
Posted on: 2009/7/17 5:53
Edited by bailz on 2009/7/17 13:18:17
