Re: alignment tool
From Sydney, Australia
Making an alignment tool is easy on a series. Get a 20 cm piece of wooden dowel that is the same diameter as the spigot bush in the end of the crankshaft. ~10-12mm from memory?
Get some electrical tape and wind it around the dowel at the same offset as where the clutchplate will sit when it's tightened onto the flywheel. Keep winding tape until the diameter matches that of the clutchplate.
Put the pressure plate over the top, and tighten down the pressure plate to the correct torques. Once its all done, remove the alignment tool. And push on the gearbox.
There you have it.. a clutch alignment tool
Posted on: 2009/8/9 1:28
Re: alignment tool
From illawarra, nsw australia
yes this is the first clutch i have ever done and i couldnt seem to get it right by feel or by sight,,,, call me blind
But another member lent me a cut up drive shaft
Works bueatifuly, had it in within 15 minutes of been home
Thanks for all the replys and sugestions
Posted on: 2009/8/8 22:34
Re: alignment tool
That 'finger' method always causes trouble for me.
But if you get the transmission partway, and have someone push the clutch pedal to loosen the disk you can shove it in the rest of the way.
Posted on: 2009/8/8 21:41
Re: alignment tool
It is simple. Just use your fingers to match the distances between the pressure plate and the friction plate. They are never a perfect match. It is a foolproof way to check your alignment. I have literally done hundreds of clutches this way and it has only failed me once. And your fingers are free!!
Posted on: 2009/8/7 11:17
Re: alignment tool
From south coast nsw
i have a cut up input shaft if u want borrow going down ur way tomoz to, pm if u want.
Posted on: 2009/8/7 9:32
Re: alignment tool
Quite a regular
From rockhampton qld
otherwise look up aust clutch services, they sell plastic input shafts for almost anything.
Posted on: 2009/8/7 9:03
Re: alignment tool
From Melbourne, Oz
Mildman wrote:
Otherwise if you have a dead A12 gearbox use the input shaft from it...
yeah do this, lots of mechanics even do it!
Posted on: 2009/8/7 8:55
"I hav achieved wood"
Re: alignment tool
From Christchurch
ddgonzal wrote:
What I do is put the clutch cover bolts on finger tight, so it can move just a little. Shove the box up in there. Remove the box tighten the bolts. Then put the box in for good.
I was going to say this, this is how I did the clutch last time on the sr. But the motor was out of the car. Might be a bit more difficult with the motor in the car
Posted on: 2009/8/7 8:48
Re: alignment tool
This spring I bought an alignment tool at the swap meet for $1, it fits Datsuns plus other cars and is made of plastic. So next time it should be easier!
Posted on: 2009/8/7 7:55
Re: alignment tool
ok thanks guys
will give it another go tomoro by eye
then if failure drive around a few parts stores tomoro theres about 4 pretty local
Posted on: 2009/8/7 7:47
