Re: Difficult to srart the Car For Idling for few days ?
If it doesn't help, let us know. There is troubleshooting for it, some simple tests.
But let's hope it works now.
Posted on: 2009/8/13 5:38
From Sri Lanka
Thanks ddgonzal
I got a clear picture now , i can see fuel from site glass of carb,so there is no leak then , i hope simply paddle it before starting will solve my problem
thanks
regards
Sumith
Posted on: 2009/8/13 5:32
Sorry I wasn't clear. Your fuel filter will never be full, nor should it be. When working correctly you will see some fuel in the filter -- a small amount or maybe half full. This is normal.
What you need to worry about is the fuel bowl. After it sits, but before you attempt to start the engine, it should display fuel in the site glass.
* If it does show, the pumping the accelerator pedal can work.
* If it is not showing in the site glass, that is a problem and will make it difficult to start.
Posted on: 2009/8/13 5:25
From Sri Lanka
Hi ddgonzal
do you mean that once i paddle my accelerator ,my fuel filter should be filled with petrol in full or my carb get filled in full ? , if not i will have to adjust it ?
thanks
regards
sumith
Posted on: 2009/8/13 4:09
From Newscastle, Australia
check your plugs, replace them with NGK BP6ES (hot) A series like new plugs..
they like fresh plugs frequently as when they carbon track in the electrodes they will cause bad starting and idling...
Posted on: 2009/8/13 1:17
Dont die wondering.....
Check your Datsun owner's manual.
Typically you need not to 'key' it several times, but instead, pump the accelerator pedal several times and key once. Maybe one pump for warm days, and four pumps for cold days (near 0 degrees).
After the car sits for several days, BEFORE you crank the engine, check the fuel bowl site-glass. Perhaps you'll find the fuel bowl is empty. In this case you need to crank the engine for a while to pump fuel to the engine before it will start. You can fix this by fixing the leak.
Another possibility is that your auto-choke is not working right, it should close 100% on the first pump. That can be adjusted very simply.
Posted on: 2009/8/12 16:11
From Sri Lanka
hi racetech
i think timing is correct because i always make timing corrected , as i am closed to the mechanic's house, i don't think so timing fault ,
thanks
regards
sumith
Posted on: 2009/8/12 12:54
From Sri Lanka
Hi bailz
i will always see it when i check the oil level, carb petrol level is always on the middle of the carb or just above half
thanks
Regards
sumith
Posted on: 2009/8/12 12:50
From Cape Town, South Africa
When last was it serviced?
Make sure the timing is correct and that the battery has enough juice to crank it.
Posted on: 2009/8/12 11:25
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
i think after u leave the car for a few days, maybe check that the fuel is still in the bowl of the carbie, make sure it still has fuel otherwise will have to re-pump and fill the bowl before it will start
Posted on: 2009/8/12 11:22
