Re: Choosing an A15 head
From Perth WA AUS
I checked and got 28cc in both heads so DD would be spot on cause both heads have been shaved.
Posted on: 2009/12/29 5:18
Datsun 1200 2Dr sedan.
What purpose? The open chamber is to reduce nitrous oxides, not to lower the compression. For the high-comp GX they used flat-tops pistons instead of dished pistons.
For the Datsun 1200, open and closed chamber heads are the same CCs aren't they? 29.3 ccs. I could be wrong.
Why don't you measure the chambers of your head and tell us what they are. I don't have an A14 head or I'd do it.
Posted on: 2009/12/29 3:25
From Melbourne, Oz
wouldent that defeat the purpose? wether that purpse be economy or power?
Posted on: 2009/12/29 3:03
"I hav achieved wood"
I thought open and closed chambers have the same CCs?
Posted on: 2009/12/29 2:46
From Melbourne, Oz
I think they came with difernt dish pistons achieving the same comp.
Posted on: 2009/12/28 11:39
From Perth WA AUS
I thought this was a lower comp head?
Posted on: 2009/12/28 11:27
Oh the H75 doesn't have the quench chamber. It'll run OK but it's not the optimum power. It's the only kind we got here in USA (we didn't get any closed chamber heads expect 1971 A12).
Either way, it's the same compression ratio as closed chamber heads.
Posted on: 2009/12/28 6:54
From Perth WA AUS
H75 head slightly ported to match GX manfold (NZ GX).
jpg  H75 head 1.JPG (71.49 KB)
9665_4b385357aceb6.jpg 778X584 px
jpg  H75 head 2.JPG (83.46 KB)
9665_4b38536559fbb.jpg 778X584 px
Posted on: 2009/12/28 6:42
From ACT
H75 heads have open chambers ports are of the low variety I think
don't look as open as the pics above
check my build thread for some average pics of a h75
First post on my new iPod touch what a cool freAking device
Posted on: 2009/12/27 13:59
Now riding dirtbikes:
Lots of A series Datto stuff for sale
What version of the A12 are you using, & this is important.
If you are using the 1970 to '73 1200 engine, then you will need a modification to use the A15 head to allow oil to reach the rockers.
If you are using a 1974 or later engine with the set-back distributor, then just bolt it on.
Posted on: 2009/12/27 12:16
Love your Datsun.
Treat it well.
