Re: Drain plug location on a12
Apologies for the flowery language. Its just that "sticks out a right angles to" doesn't roll off the keyboard quite as nicely.
Posted on: 2010/1/27 5:27
One looks to be protruding hexagonally, but the other looks to be protruding circularly. Could be just the photo?
Posted on: 2010/1/26 5:29
SunnyDaze wrote:
One is directly below the welch plug protruding orthogonally from the block. The other is below and behind the welch plug and protruding at an angle.
Orthogonally? Well I live & learn. I had to look it up but that's another word that I can add to my vocabulary.
Link 1
Link 2
Link 3
Orthogonal entertainment
Oops, edited to correct blatant spelling error.
Posted on: 2010/1/26 1:35
Edited by Dodgeman on 2010/1/26 7:24:19
Love your Datsun.
Treat it well.
M22: A12 block casting from 1974-1978 B210
Posted on: 2010/1/25 21:12
Yes, that is the block casting number.
Posted on: 2010/1/25 19:22
Not sure where to check the casting number, but it says M22 where it says M72 in your picture of the late model engine.
Posted on: 2010/1/25 9:34
Which block casting number is that?
H79 or H50 ???
Posted on: 2010/1/25 5:21
Thanks DD. I have a late model a12 and it appears I have both bolts! One directly underneath and one behind.
jpg  IMGP3105_s.jpg (54.86 KB)
7711_4b5d1a8e267b8.jpg 800X532 px
Posted on: 2010/1/25 4:02
That photo above is the late-style engine. So a 1974 A12 will have it there.
The early A12 engine (1970-1974) has it in roughly the same position, but exactly under the center welch plug.
Posted on: 2010/1/25 3:36
It is just below the center welch plug on the left (manifold side) of the engine block. This appears about halfway down the side of the block:
It is only halfway from the top because below that is the upper half of the crankcase. The water passages only go half-down the block.
Posted on: 2010/1/25 3:27
