Re: CA18DET 1200 radiator question
From SE Melbourne
Sounds like next time I change the rad I should go SR - the CA does make it pretty difficult to get the top rad hose past the intercooler piping (I've got to go dig up a new top hose as I had to take the CA original one off once I fitted the intake piping )
Posted on: 2010/1/26 0:51
Mildman, Datsunless
From brisbane
I have been using one of the Ebay SR 30mm thick ones for the past couple of years without issue. I am currently upgrading to a 50mm thick SR one at present.
The SR outlets make it a bit easier to avoid the throttle body and intercooler plumbing.
Posted on: 2010/1/25 23:38
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From hastings,vic
i use a hyundi rad
top hose in the middle
rad a bit shorter to
Posted on: 2010/1/25 14:06
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
every things always for a reason, good or not
Posted on: 2010/1/25 12:36
From Melbourne, Australia
yes good point(s)
i did measure today i have about 100mm from radiator mounting face to engine crank
not much room for a rad and thermos
would have to have another look at mine to see how much the throttle body woul be an issue?
not sure how the old setup was with my motor but someone has gone to the effort of cutting and re-welding the thermostat housing to face the other way.... probably with good reason
Posted on: 2010/1/25 12:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
not with the blower set up fitted really he doesnt. im not sure it would be enough to the l series water pully either but i still have a little room on the rad support side.
Posted on: 2010/1/25 12:31
I was thinking of using one in my CA conversion but my preference was for an SR20 style inlet/outlet as it keeps the top hose away from the throttlebody
piping. Anyway, the reason I didn't go that way is because they are so much thicker than the stock units and I wanted my intercooler neatly hidden behind the standard grill and also room for thermo fans at the back...space is always at a premium with conversions like this.
Superfatto has an A series engine in his so probably has a bit more room to play with!
Posted on: 2010/1/25 12:21
well there ya go, im at supafatmans for a bbq tomorow so i will see first hand, cheers guys
Posted on: 2010/1/25 12:20
1200 Coupe Rallycar
From Mandurah, Western Australia
Alot of people use this radiator. Especially if they started with a half cut.
Posted on: 2010/1/25 12:16
supafatto did ;)
