Re: A15 HP questions
From Snohomish, WA USA
to answer DDGonzal, i have the rear end off of a B210 and a Dogleg transmission out of the B210GX, so i dont think i will be breaking anything
You should have no problems with that setup but I went a step further with the A15 supercharged/nitrous and the lock rearend. Went through both the H150 and H165 rearends before blowing the motor. The only thing that lasted was the 5 speed tranny. I wish I would have had the motor dyno'd when it was at its peak performance but if I had to take a guess, I was probably pushing 120hp. Maybe a bit more. The A15 was pushed to its limits. I was sorry to see it go.
Posted on: 2010/2/8 15:55
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Midway City, California
Posted on: 2010/2/8 15:25
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
The larger ports will allow more gas flow, but the GX valves are smaller than the A15 valves, so you loose what you might have gained because of this.
The A15 head is very well suited to the A15 engine for almost any application except 'balls to the wall' race engines, however with suitable mods, they will serve well in this application too.
A modified A12GX head has more potential in a race engine, but again, really only in an all out engine.
Posted on: 2010/2/8 12:35
Love your Datsun.
Treat it well.
From Melbourne, Oz
90ish?
Posted on: 2010/2/8 10:55
"I hav achieved wood"
Not too shy to talk
if you put gx head with its twin carbs on your a15, how much HP will you think it will make?
Posted on: 2010/2/8 10:51
Well an A15 feels twice as powerful as an A12. Just make sure to use an A14/A15 transmission and rear end, as the A12 ones are not strong enough.
Posted on: 2010/2/8 5:13
yeeeeaaaahhhh.......no
id rather just keep the A15 in there, im planning on keeping it daily
Posted on: 2010/2/8 5:09
From perth airport
go a newer turbo efi motor
Posted on: 2010/2/8 4:41
perth airport parking
Datsun 1200 ute A14
All car engines are rated at the flywheel. Only aftermarket engines are rated at the wheels.
Posted on: 2010/2/8 3:47
From Brisbane
an thats at the flywheel isnt it? lol
Posted on: 2010/2/8 3:19
