Re: stanza struts with r32 rotors and calipers anyone?
From newcastle
yeah will let you guys know when i get it done hopefully post some pics
Posted on: 2010/5/16 11:50
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
From Geelong, Vic
there are pics on the sight of him bracket, i had a good look at them when i did mine...then just did it from scratch anyway
i found it easiest to just make the disc fit the hub, then put the caliper on with full size pads so it can sorta hold itself on there, find a spot it fits well then start making templates
made about 5 different templates before i was happy with where the caliper was
Posted on: 2010/5/15 13:11
From newcastle
remember ca18detman, ran in to him today and had a yarn he reckon he swapped struts from left to right,and reckons he still has a template for the bracket, things are looking up
Posted on: 2010/5/15 12:53
From Bendigo Vic
thanks for the info i have gave datsport a call and i just goin 2 get everything off them as a bolt in package, just got 2 get some money 2 gether
Posted on: 2010/5/15 0:49
From Rosewood, QLD
id like to try jamming some of these on my Nav
Posted on: 2010/5/14 12:23
1971 B110 sedan project.
2012 Nissan Micra daily.
From Geelong, Vic
could alway use r31 struts or something if you dont have any luck with the stanza ones. datsport do a bolt on bracket for skyline brakes onto them
how my car went with the front brakes, as in how well it stopped. well ive got r32 rear brakes on it aswell so they help, but dont think they were getting enough pressure to really do much. but yeah, with a booster and r33 mastercylinder it stopped very very well. most normal driving in traffic kinda stops you could do with your little toe and only about a half inch of pedal movement
never really hammered them on as there was always something inside the car that would come flying forwards at me, and also with the brake bias needing more sorting the front would lock up if you jumped on the brakes too hard...crappy tyres and lots of static camber didnt really help either
but compared to other brakes in 1200s that people reakon pull the car up well...these are a whole different ball park
Posted on: 2010/5/14 10:10
From newcastle
also just wondering how your car went with the rotors on the front braking wise?
Posted on: 2010/5/13 9:21
From newcastle
yeah pigdog looked at your photos wich where helpful, thing is i already have r32 gtr rotors and calipers and have machined the rotors out to suit the hub (and machined the hub a little aswell). would like to try and use what i have for now and try to make it work(hopefully) yes the ball joint does sit a little close to the rotor but yeah as you mentioned a spacer may be the go if it causes dramas. will let people know how i go with this when i work it out and get pictures up soon
Posted on: 2010/5/13 9:17
From Geelong, Vic
if you want to use the standard mounting ear and make a bracket off them, you need to use an r33 gtst disc, and an r32 or 300zx caliper. otherwise the mounting ears of the caliper will hit want to occupy the same space as the strut mounting ears, if you were to use matched brakes(r32 disc and caliper etc)
you can swap struts left to right to change wether mounting ears are at the front or the back, my calipers are at the front as they dont fit at the back
you say you looked at the wiki...but did you look at my strut and brake upgrade guide thats on the site?(which probably doesnt go into much detail in it but it mentions it) should really be put on the wiki but i havent got wiki creating skills
one problem that apparently arrised when using 200b/stanza hubs and the skyline disc is that the disc gets very close to the balljoint if you use stanze steering arms, im using 200b ones as they have an offset hole so give more clearance, and a bit more track width
balljoint tapers are slightly different though so a smacer of sorts should be idealy made up
here's some pics of the finished bracket anyway
aido, look here should give you the info you need
Posted on: 2010/5/12 8:54
From Bendigo Vic
hey
i was goin 2 use r31 struts and brake on the front of my ute, has it been done before?
Posted on: 2010/5/12 8:30
