Re: Raspy Noise Coming From Gearbox- Clutch Related
From Freo
mabee the spigot bush...
where ya shaft goes into the hole..
Posted on: 2010/5/14 6:00
A15 PSI Project Motor
'72 CB750k,
Oh Dan, By arms I meant the throttle linkage that goes from throttle shaft to carby.
Bled the brakes for hours, I can get pressure after a fair few pumps and the pressure holds but there seems to be an air-pocket somewhere. Annoying.
Posted on: 2010/5/14 5:43
Went for a blocky or two. Nasty stuff, way out of tune.
Danny I need those arms aye, these ones are different lengths and it's getting all messy. I also need some tiny little screws that hold the bracket on. Don;t like my chances on finding any that aren't OEM.
So how long have I got till this bearing dies?
Just drop your box.....LOL
Posted on: 2010/5/14 5:36
From SA
ill have a look tomorow :) most probs yea
easy aschange tho chris just gotta drop box
cheers
Dan
Posted on: 2010/5/14 5:22
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
most probably... mine does it too, and did with the a series too. only when cold
Posted on: 2010/5/14 4:05
When I press the clutch in I get a screeching raspy noise from the gearbox! I don't know gearboxes too well but is that the thrust bearing (??) I can hear?
Posted on: 2010/5/14 4:02
