Re: DCOE or DHLA whats the difference????
does anyone know anything about the starter discs on phh40 carbs
yes they perform the same function as a choke. A little external spring keeps the starter OFF (anti-clockwise). Your choke cable will turn it clockwise for starting.
Posted on: 2010/10/3 19:41
From mandurah
hhmm mike when you coming around to tune my carbys ,and sorry for hijacking this thread but does anyone know anything about the starter discs on phh40 carbs
oh and i paid for mine with parts but nigel paid 150 or 200 (not 100% sure)for them ,with a manifold and linkages
Posted on: 2010/10/3 14:40
Edited by estyre on 2010/10/3 15:01:33
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Freo
$600 in my book would be top dollar for the DHLA's, unless new/rebuilt,
a pair is usually about 2-300, DCOE's tend to be a little more..
Posted on: 2010/10/3 11:15
A15 PSI Project Motor
'72 CB750k,
From Malaysia
my solex addhe 40 also have the ported vacuum outlet for the dizzy advance.
Posted on: 2010/10/3 9:39
Difference:
Twin Dellorto sidedraughts were factory fitted to the Datsun 1200 SSS
Weber DCOE can be ID'd by the round brass fittings on top
Mikuni Solex have round aluminum starters close to the manifold.
Posted on: 2010/5/20 5:16
Apparently Dellorto Jets also come in smaller increments than Weber, which might help if youre having problems tuning.
Posted on: 2010/5/20 0:39
In all honesty if I were to offer any advice on the purchase I would suggest that you go for a complete setup, that has come off a running engine, carbs manifold & linkages. I know it looks like alot of money upfront but it is worth it in the long run.....nothing worse than dickin' around with carbies. Well it's fun to learn but it gets annoying when it's keeping you off the road (which is my situation).
If they're in good condition and the jetting isn't too far off then they're worth that price range. Otherwise drop a $200 bid down and the $600 will disappear (it should anyway) and you'll have a better chance of owning them at a cheaper price. But of course be prepared for additional bids later on.
EDIT: Here are some cheap Mikuni Type-T's you just missed out....They're a great carb.
Mikunis
See what I mean by cheap.
Posted on: 2010/5/18 12:44
Edited by clyons8 on 2010/5/18 14:07:24
Edited by clyons8 on 2010/5/18 14:07:43
From Sydney
Oh totaly different brands..... right.
what would you expect to pay for a set of dhla carbs no manifold.
they are on ebay buy it noe 600 or opening bid of 200
Posted on: 2010/5/18 12:38
One thing I'd like to mention is the fact that Solex Mikuni Type-R's have a vaccuum outlet for the vacuum advance on your dizzie. A neat little feature that the other two makes don't have.
If you go for some bike carbs I reckon you could use the vacuum reference lines for your vacuum advance as well.
Posted on: 2010/5/18 11:26
From Sydney, Australia
DHLA = dellorto sidedraft
DCOE = weber sidedraft
same manifold thank god.
Posted on: 2010/5/18 9:56
