Re: Twin 40 DCNF Weber side tracker project
From Malaysia
sweet.. what angle are those carbies? the rocker cover are sick though..
Posted on: 2010/6/28 20:08
Yeah okay so how far off are the spacings? Or more-so do you work the manifold or the head to make the alignment? I'd like to try out some twin Weber DCD's one day (they'd have nothing on those!).
Posted on: 2010/6/27 15:05
From Sydney
Definately fits under a 1200 bonnet, the ram tubes sit no higher than the std air filter assembly. Should clear the bonnet on a "K" as well i'm guessing
Posted on: 2010/6/27 11:49
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Splendid!
Velocity stacks look great. Looks like they'll just clear the bonnet too? of if they're too close you could put louvers through the bonnet? May not be your thing though.
Sweet.
Posted on: 2010/6/26 12:37
From Sydney
I picked up the carbs 5 to 6 years ago off a triumph nut in the UK. I guessing the manifold is off a triumph.....
Posted on: 2010/6/26 12:27
1970 KB10 Coupe
S13 caliper b...
Very Nice Benny, Ive been looking at the 36mm idf version and wondering if what
you have pictured could be done as they are compact short in height.
is the manifold a 1500 fiat non crossflow item?
Posted on: 2010/6/26 12:08
Re: Twin Weber side tracker project
From Geelong, Vic
and you know that its the rocker cover that will attract the most attention
Posted on: 2010/6/26 11:25
From Sydney
I thought it may be time that I would share my progress with my long term twin Weber 40 DCNF induction project.
I have always been a fan of the downdraught synchronous webers. These little suckers are 40DCNF's . Typically they can be found on Italian thoroughbreds such are Ferrari and Maserati.
With the right jetting I plan to tune these on a hot A15 just to be different. The manifold is a close match to the A-series head port spacing and shouldn't be to hard to make it work.
Take a look at the pics and let me know what you think.
cheers
benny
Posted on: 2010/6/26 11:21
Edited by benny on 2010/6/26 11:46:23
1970 KB10 Coupe
S13 caliper b...
