Re: a12 turbo
Topgear 100kw atw with single stromberg 1.75
problem is how to stop the oil blowing out
with the ball bearing turbo he used from a
twin turbo liberty. great turbos they spool
up quickly. Someone somewhere mentioned to
me that its possible to fit some kind of flap
as you cant fit an oil seal on these turbos
but dont know the details now.
They are much better than normal non bb turbos.
Posted on: 2010/11/11 21:37
Re: a12 turbo
i would like to know how much extra power you get from water/meth setup too
Posted on: 2010/11/11 11:16
Re: a12 turbo
hey frank what sorta power did u get with the a15? and what boost as im looking at getting water/ meth setup and need to sorta give them a power output for nozzle size, im thinking my a14 t25 with a little port work and recent bottom end rebuild that id be looking at bout 130rwhp is this about true from a cd175/ 1 3/4su draw through setup??
Posted on: 2010/11/11 10:04
Car free
Re: a12 turbo
From Brisvegas, oz
after building carby setups and then going efi, i wouldnt go back ever. power and efficiency is better.
Posted on: 2010/11/10 6:43
www.camerasplus.com.au
Re: a12 turbo
I prefer the old look of polished stromies or sus but
the MSR look nice polished as opposed to standard
jpg  msr 45.JPG (89.04 KB)
737_4cd9ea79f0828.jpg 460X367 px
Posted on: 2010/11/10 0:41
Re: a12 turbo
Interesting you mention the HSR.
I have a Keihin CR Special (big bore) for exactly the same purpose.
Posted on: 2010/11/9 15:09
Re: a12 turbo
Efi will make it easier to make it more drivable but it will have he same power as the carby equivalent.
I will be using a carby on my draw through setup - Mikuni HSR 45. It has an accelerator pump and looks sick bolted the the front of a turbo and can even be brought polished if wanted. Being a motorbike carb with a CABLE operated slide the tuning would take an arvo.
I've thought of EFI but after getting all the sensors and hooking it up and the big bucks invested - you have to send it off to get tuned which I couldn't bare as I like to do my work myself.
For a first time attempt at turbocharging I'm all for the carby but to the experienced person EFI is a good alternative.
Posted on: 2010/11/9 9:43
Re: a12 turbo
From mandurah
im collecting the bits for a turbo build at the moment
is efi the best option for tuning (ease of tuning) ???
and will it make more power with a low tech computer than a good carby setup eg 175CV stromberg ??
what would be more reliable in the long run ?? carby is simp,e and seems easyer
Posted on: 2010/11/9 8:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: a12 turbo
From Pretoria SA
A12, A14, A15 the price would be more or less the same to do. The a14 and a15 would only give more power.
The more you can spend the more power, but check out the "search block" on the left of this page, you would find a lot of info like that on this site
Posted on: 2010/11/9 8:43
1400 Turbo
Re: a12 turbo
From Brisvegas, oz
i suggest doing some engine searches using the button on the side, as these two topics are often asked about.
but in short, power depends on money but on average turboed a a12 will give around 90kw atw depending on a multitude of differences. cost is starting from $0 (if you have the part and going up to Thousands and thousand.
Posted on: 2010/11/9 8:16
