Re: Help identify these seals.....
From Seattle ,WA.
Scott's rubber sent me some pic's of there boot seal, its the 322-018 seal - its looks a lot like the big one I have so I assume mines for the trunk, I'll try it and see.
http://www.scottsoldautorubber.com.au/page29.jpg
still am not sure what the other ones for - I suppose inside the glass wiper seal maybe but dont see how it'd really fit in properly.....
Posted on: 2011/1/20 6:01
From Perth WA AUS
That make sense, I forgot about the furry bit.
Posted on: 2011/1/18 11:12
Datsun 1200 2Dr sedan.
From Ringwood, Melbourne, AUS
The rear 1/4 windows use a pinchweld type rubber and the boot seal appears to be wedged/glued under the lip around the boot opening.
I think the smaller one is for the inside of the door windows, the vertical piece sits on the top of the door trim, the bit down and to the left slides against the glass (the furry bit is on the bottom of that part right, so would rub against the glass?), short bit out to the right wedges into the metal slot in the door trim??
Posted on: 2011/1/18 10:22
Deano
From Perth WA AUS
I'd think the top seal (big one) would be for the rear side windows and the other is for the boot (trunk) but its not quite the right shape.
Maybe check the length of the seals as a rough guide to where they should fit, they will probably be slightly longer than required.
Posted on: 2011/1/18 9:24
From Seattle ,WA.
possibly the inside door window seal,
not sure what you mean - do you mean the rear seat/vent window or inside the door somewhere?
thx.
E
Posted on: 2011/1/18 6:15
From Geelong, Vic
smaller one is possibly the inside door window seal, looks kinda the right shap but looks pretty big
Posted on: 2011/1/18 2:55
From Seattle ,WA.
I bought a kit from one of the Thai guys a few years back that I thought included all seals - front & rear windshields, coupe side tip out rear windows, door seals & trunk lid. Now I'm stumped, I dont know which one fits the trunk seal & what the smaller one is for (its got a fuzzy surface like Baily channel molding.
At this point I cant remember if I got a trunk seal with it, the one that has the pinch weld attached looks like it would work for the rear side windows but I'm not sure. Anyone have pic's of the originals for the side windows & trunk seal or have any idea what smaller one is for?
Thanks!
Posted on: 2011/1/18 2:08
