Re: Master Pump Problem
From Perth
Yup. thats what I mean
Posted on: 2011/2/20 3:40
From Sri Lanka
Hi dattoman_1000
do you mean piston with the 2 seals closer has to face each other ?
thanks
regards
sumith
Posted on: 2011/2/18 11:08
From Perth
Picture shows piston at bottom
Those seals look right way around
Other piston the 2 seals close together are supposed to be opposite each other... hard to tell by pic
The one closest to end has lip pointing back up the bore oppositre to all the others
SO 4 face down the bore... and the one faces up
Put the bottom piston in and push it down with a screwdriver and hold it all the way down the bore
Then fit small screw that stops the piston coming back too far
Then release the screwdriver and the piston pops back and stops on the pin
Then refit top piston and circlip
Posted on: 2011/2/18 10:59
I don't know how to interpret that.
I have only had trouble with rebuilt cylinders, so I only buy remanufactured (or new) ones. Other mechanics report good results with rebuilding them however.
Posted on: 2011/2/18 7:11
From Sri Lanka
Hi DD
Yes i only used brake fluid nothing else, when moving outer piston downwards do you feel the inner piston is also moving ? i feel only outer piston moves down and come up only
is that the problem there ?
but individually i checked them both are moving down and up
thanks
regards
sumith
Posted on: 2011/2/18 7:04
If you put oil in it, that is a problem. Only Brake Fluid should be used.
Yes chris, that's correct. Push in the piston, then fit the screw to limit the front piston travel. This is for a double-outlet Master Cylinder.
And yes, the Master Cylinder must be bled by cracking the lines at the cylinder, before proceeding the bleed the wheel cylinders. All air must be removed.
Posted on: 2011/2/18 6:49
I pushed the internals of the master cylinder all the way in and then screwed that small screw all the way in. It is intended to limit the travel of that cylinder, I THINK if it isn't in correct place the cylinder will not prime and keep pressure.
It also helps to prime the master cylinder or bleed it directly off the cylinder (there should be two small bleeding nipples on the actual master cylinder?) I found that if there was air I could not bleed the brake system properly.
Posted on: 2011/2/18 6:45
From Sri Lanka
Hi DD
Actually Yes, i have removed old brake oil and replaced all the washers on brake drums and also bought a rebuilt washer kit that suit for my Master pump, the size is 11/16
when pumping brake master cylinder sucks little oil and also can hear a little air sucking sound from the small hole in the reserver , but not Cluth reserver does similer, but none of them bleed oil down
fixed it so oil bleeding so removed it to bench test it
and filled oil and pumped it several times but no oil coming from , when you pump front piston it moves down and return back normaly,
is there any specific mechanism to instll small screw under the pump,after inserting clutch piston into the master pump , do i need to put small screw down or after installing both
thanks
regards
sumith
Posted on: 2011/2/18 6:37
it looks correct to me.
Did you bleed the master cylinder?
Posted on: 2011/2/18 6:22
From Sri Lanka
Hi DD
Do you see any mistake on this if this is clear, all the washers into same side is it ?
i have installed them Curved Area to opposite side of the piston head side, is it the correct way
thanks
regards
sumith
jpg  DSC00210.JPG (66.77 KB)
10994_4d5e0c35dfc58.jpg 640X480 px
jpg  DSC00211.JPG (75.82 KB)
10994_4d5e0c9922dab.jpg 640X480 px
Posted on: 2011/2/18 6:07
