Brake options for 1971 1200 sports c
From Castro Valley,CA USA
Posted on: 2001/12/25 5:27
Re: Brake options for 1971 1200 sports c
I used those bigger cylinders in my sedan. They bolt straight in. BUT!!! They do have more braking power and tend to lock-up before the stock front brakes in panic or hard
braking on the street. This is the same as pulling the e-brake and spinning in circles. you may wish to look at a brake bias valve also.
Posted on: 2001/12/25 5:23
From Arlington, TX, USA
Try a PL510 (1600) wheel cylinder. They are a little bigger, but bolt right on.
By: datsun1200_510_521
Date: 12/21/01 10:13 pm
I am having difficulty finding wheel cylinders. Both Napa and CarQuest do not have
any available.
What is an easy bolt on rear brake motifications; What model will fit the rear axle?
Posted on: 2001/12/24 9:17
Thanks for the hint. I will check with my local supplier.
I found a place online that appears to have some stock and reasonable prices. Also some suspension parts
that might be helpful.
http://www.benzspring.com/
Posted on: 2001/12/22 6:19
From Tracy ,Ca
wheel cylinders from later b210
should fit the 1200. They have a larger bore, which will increase braking power.
Bob
Posted on: 2001/12/22 4:00
From Sydney, Australia
dont TRX series 2 rear disks bolt right on?
just a thought...
Linc.
Posted on: 2001/12/22 3:56
Brake options for 1971 1200 sports coup
I am having to redo the rear drum brakes on my "new" coup. I am having difficulty finding wheel cylinders. Both Napa and CarQuest do not
have any available.
Does anyone have a source? OR
Thanks, Ed
Posted on: 2001/12/21 10:13
